Results 1 to 10 of 17
- Apr 2008
- 21
May 30th, 2008 07:21 AM #1Hello Sirs,
Ask ko lang what is the correct tire pressure for 1996 Honda Civic VTEC VTI Automatic. Normally kasi, 35 PSI ang gamit ko for both front and rear tires.
Now that all prices are high, I need to know this para sa Fuel Efficiency.
Thanks in advance.
BANNED BANNED BANNED
- Jul 2003
- 2,267
May 30th, 2008 09:17 AM #2i am not particularly sure what the required tire pressure is for your car but i am pretty sure 35psi is quite high. 29-31 would be safe i think.
you can read your can manual for the right specs or look for the sticker at the located near the locking mechanism of the driver side door.
- Apr 2008
- 21
May 30th, 2008 07:26 PM #3Thanks for your reply. Sinunod ko advice mo, ginawa ko nang 30 PSI all tires.
May 31st, 2008 01:48 AM #5
June 2nd, 2008 04:49 PM #6
I run mine at 34-35psi, hindi naman matatag. The maximum recommended pressure for most tires nowadays is 40-42psi, and that's actually a fairly conservative number.
In general:
Low pressure: softer ride, possible tirewall flex (leading to uneven tire wear and sloppy handling), higher fuel consumption
High pressure: firmer ride, tighter handling (pero konti lang), lower consumption
Find your personal preference nalang based on feel.
June 2nd, 2008 08:51 PM #7
^^ hmm if i remember correctly, the lower the psi will result more rubber contact... hence better handling. (roll resistance)... wag lang sobrang low like 24-26... yari ka dun.
38-40+ psi is too much... sureball, uneven thread wear sa gitna.
i run mine at 32 front 30 rear...
- Dec 2008
- 421
December 12th, 2008 04:47 PM #8for sedans its 31psi if it is cold and 33 psi hot
(i recommend 30 but when you pull the airhose from the valve i automatically lose 1psi thus 31 psi is my recommended pressure)
For SUV (pajero)
31 front/37 rear
for mud off-roading only
15-24 psi (for maximum contact patch)
Spare tyre= 45 psi (since i only add air to it every other month.)
December 12th, 2008 06:31 PM #9
based on the manufacturer's recommendation, i find it a bit under pressure. probably for their own benefit that the suspension won't get laspag within the warranty
what i do is: add to go up by 2 or more psi than recommended then observe the handling and at the same time, visually check kung hindi naman medyo "dapa" that can cause early damage on the sidewall (cracks, bukol etc)
another is yung hindi marurumihan yung thread malapit sa sidewall - malambot yun
- Dec 2008
- 421
December 16th, 2008 05:44 PM #10
2025 BYD Seal 5 Premium Review: Best value hybrid at PHP 1.2M? AutoIndustriya - - - - - - - - -...
BYD Philippines
