Results 11 to 20 of 27
- Jan 2009
- 82
March 4th, 2009 02:02 AM #13
this is too low IMO. baka wala ka na fender gap dito sa 15's and 50 series. ill take 1.5 inch drop para aggressive look, comfort, and hindi sasayad on ever stone you pass by. :bwahaha:
tein, have excellent coils and lowering springs but cost a bit higher than other brands.
March 4th, 2009 02:19 AM #14
March 4th, 2009 02:48 AM #15
Anung car po ba?
mas matag tag ang springs lang IMO
Tanabe Sustec pro NF ok yun
not as expensive as tein superstreet pero mas soft ride nya
by the way the NF stanfd for normal feel
HTH
March 4th, 2009 02:59 AM #16
kasi generally, when COs or lowering springs are installed sa mga tsikot naten, the ride tends to be stiffer. lowering springs compared to COs less stiffer, but still noticeable decrease in degree of ride comfort. some of the high-end COs/lowering springs are much much pricier compared to others is because of the near stock, if not better ride comfort while achieving the look you desire and the performance upgrade we dream.
H&R pa lang nasubukan ko with regular gas shocks. I use KYB and H&R on my Nissan B12 and okay pa ren cia for me. konti lang difference sa stock ride ng N16 ko.
Bilstein, best ko nasakyan.. then Tein kaso.. mahal siya sobra para sa kagaya ko.
March 4th, 2009 04:11 AM #17
di masyadong halata ang drop ng 1.5 drop ng H&R specially combine mo s a KYB gas shocks, based sa experience sa lancer di ko lam sa ibang model, yung stock oil shocks ng lancer medyo mababa compared sa gas
- Aug 2005
- 205
March 4th, 2009 08:49 AM #18its automatic, once you lower the car or alter your suspension to be performance oriented, it will be stiffer to reduce body roll. the combo i mentioned gives a very good compromise of performance and comfort. matagtag ng konting konti sa stock, in my experience negligible. but body roll is significantly reduced.
March 4th, 2009 11:16 AM #19
- Jul 2008
- 4
September 12th, 2009 12:34 AM #20for lancer 01 pwede bang combine sa shocks ng lancer itlog(fluid type)+ H&R lowering spring 1.75 drop?
Don't think about other brands anymore, just go with Amaron. It lasts minimum 5 yrs+ parati, I just...
