Results 531 to 540 of 645
- Dec 2006
- 234
August 19th, 2011 05:11 PM #531
- Aug 2011
- 28
August 21st, 2011 03:53 AM #532Sir my accord is a 5th generation 1995 with ph20 engine, M/T, PGM-FI, Non VTEC. papaano ko po malalaman displacement nya? also ang valve configuration nya. Di po kasi nakalagay sa CR nya engine displacement. Ano po kaya equivalent nito sa Honda Accord Wikipedia? 3rd owner na po kami at di ko na natanong pinagbilhan namin 1 year ago. Thanks
- Oct 2008
- 944
August 21st, 2011 03:03 PM #533*sleepsus
yesterday i seem to get 2.5k rpm kapag 80km/h tapos 2.9k rpm kapag stable 100km/h
*all and arnel9872
source from http://tsikot.com/forums/car-compari...88/index2.html
from our fellow tsikoteer, hope that helps!
- Dec 2006
- 234
- Jan 2011
- 16
August 28th, 2011 04:02 AM #535Good day po sa inyong lahat mga Accord Brothers...
Ask ko lang po sana kung ok po bang mag check-up ng makina sa Honda Dasmarinas Cavite? Taga Cavite po kasi ako and gusto ko po sanang ipa check-up ang '94 Accord ko sa Honda Dasmarinas... If you have some comments on Honda Dasmarinas Cavite good or bad it would be a big help po sa akin... Thank you po sa inyong lahat in advance...
- Aug 2011
- 28
September 6th, 2011 04:10 AM #536Mga sir baka po may experience kayo regarding sa na e-experience ko sa 5th Generation Honda Accord sedan ko 1995 2.0 cc m/t. Basta po nasa mga less than 1/4 nalang fuel ko as per my fuel gauge eh I will loose power upon sudden breaking on 4th or 5th gear as in dropping to zero rpm.. starting again is no problem. I am not experiencing this as long as I am more than 1/4 of fuel. Also idagdag ko narin po na pag less tha 1/4 fuel ko, ay hindi ko na ma start pag nabitin ako sa garahe namin which is somewhat inclided, paurong po kasi ako mag park. Is this something to do with the fuel pump position inside the tank? Fuel tank problem? or pump? This car runs so well and very efficient at FC is good, ito lang po medyo na pu puzzle ako sa sudden loss of power nya on less 1/4 of fuel on sudden breaking and on a downward position. Any recomendation what to check? Thanks po.
- Dec 2006
- 234
September 8th, 2011 02:54 AM #537i haven't experienced that myself, but it sounds like the uptake tube of the fuel pump has a leak above the inlet
- Dec 2006
- 234
- Oct 2008
- 944
September 8th, 2011 01:38 PM #539ganda sir! kaso ang di ko lang talaga ma-appreciate sa rides natin is yung front bumper. ok naman kaso parang para sa akin parang submarine type kasi parang pabilog na ewan yung korte. pero nonetheless, happy naman ako :D
- Dec 2006
- 234
September 8th, 2011 02:25 PM #540
Agree with you there. Nicely put.
2022 Mazda BT-50 (3rd Gen)
