Results 1 to 10 of 14
October 4th, 2006 09:32 AM #1
magpapapalit sana ako ng engine ng hatchback kaso i dont know nothing
about honda engines may nag advise sakin na either B16 daw or PH16 daw
palagay ko! anu po ba pinagkaiba nung both engines and kung anu mas
maganda lagay sa hatchback. Thanx Po
October 4th, 2006 10:26 AM #3
PH16 is the local version of the D16 engine ng honda. Tama si wrcastro_ph, around 120hp ang output nito. Merong VTEC and non-VTEC versions na lumabas.
B16 naman, you basically have 2 choices, B16A or B16B.
B16A:
# Displacement: 1595 cm3
# Compression: 10.4:1
# Power: 168 hp * 7800 rpm & 116 ft·lbf * 7300 rpm
B16B:
# Compression: 10.8:1
# Power: 187 hp (137 kW) * 8200 rpm & 118 ft·lbf (160 N·m) * 7500 rpm
Masmahal syempre ang B16 series engine kaysa PH16. Ang surplus ng PH16 mga 20k or so. B16 series will burn you for 80k above.
October 4th, 2006 01:21 PM #5
b16 na para pasok ka ng 14's sa 1/4 mile! hehehe... matulin! kaso make sure n mag uupgrade ka rin ng brakes dahil mahihirapan ung stock brakes mong awatin ang b16!
October 4th, 2006 02:23 PM #6
Oo nga mag B16 ka na lang.Huwag ka magnon vtec mabibitin ka lang tulad ko..hehe..Gawin mong carb para pasok ng mga less than 13 sec baka nga 11 sec pa..
October 5th, 2006 08:31 AM #8
October 5th, 2006 08:38 AM #9
if you want performance b16a (yung b16eg).. type r engine na yung b16b mejo mas mahal yun. kung economic naman, sa d15b ka, kung gusto mo matipid at mabilis.. turbo mo na lang d15b
One can only hope.
