Results 11 to 20 of 31
May 23rd, 2010 05:25 PM #11
When you change at <1.5k rpm will it affect fuel consumption than changing at <3k rpm?
Also, when you coast on gear or when decelerating on gear would it affect fuel consumption rather than going neutral and just stepping the brakes?
Lastly, when the paper says max power 105hp * 6000rpm and max torque 102 ft lb * 4000rpm. What does it mean?
Thanks!
May 24th, 2010 12:30 PM #12
Depends if your ride can take it. Most gasoline vehicles will lug if you change up at 1.5k rpm, because that puts you at just 1k rpm in the next gear.
Cars don't use very much gas on coastdown. And if they're EFI, they hardly use any at all.
It means your car makes the most horsepower at 6000 rpm and the most torque at 4000 rpm. Which means that, typically, for best acceleration, you want to keep the engine revs between those two points in each gear.
May 25th, 2010 01:31 PM #13
Thanks sir niky!
Nag inuman kasi kami at pinag dedebatehan namin yung coasting on neutral vs coasting on gear kung ano ang mas malakas sa gas at mas matipid.
Ang argument ko mas malakas sa gas yung neutral kasi naka idle yung makina, kaysa sa coasting kasi hindi gumaganmit ng gas dahil sa engine cut of ng gas.
Thanks po!
August 23rd, 2010 02:30 PM #14
paano kapag mabilis ang takbo then medyo bumagal then speed up ulit. kailangan pa bang mag change ng gear?
August 27th, 2010 12:42 AM #15
depends on how slow and how fast you want to be, depends also on the engine.
if for example you are on 3rd gear * 4.5k rpm and slow down to 2.5k rpm you wouldn't change gear if you wanted to accelerate again. but if it dropped to 1.5k rpm and wanted to accelerate again, its better to shift to second and shift to 3rd * 4.5k rpm. something like that
- Mar 2005
- 703
October 4th, 2010 03:57 PM #17
kaso bossing eh sira ang gauge ko, hindi ko pa kasi napaparepair kaya hindi ko rin matantya yung speed ko kapag tumatakbo.
dagdag din sana ako ng scenarios:
- Let's say nasa 4th/5th gear ka, then biglang may tumawid pero hindi mo kailangan ng full stop. Ano ang tamang gawin? kailangan bang magshift gear after mo bumagal kahit tatakbo ka na ulit ng mabilis?
- Paano naman kapag, asa 4th/5th gear ka, mabilis ang takbo tapos suddenly kailangan mo na bumagal kasi traffic na pala(assuming hindi nakita sa malayo), kailan dapat magpalit ng gear? at sa anong gear, ok lang ba deretso 2nd or first gear?
- At regarding na din kapag decelerating ka na,let's say nasa 3rd gear ako then medyo traffic na, nalilito pa rin ako kung dapat na ba magshift gear pababa, kasi madalas eh parang kumakadyot* ang sasakyan ko kaya minsan hindi na lang ako muna nagshishift ng gear, kapag sobrang bagal na lang. (*sorry sa term, hindi ko alam ang tamang term eh)
October 4th, 2010 04:05 PM #18
Magmatyag ka bro sa takbo ng engine mo. Usually what I do kung nasa fifth gear at me slowdown, I drop directly to 3rd. From 3rd to 5th uli if okay na uli ang trapik. Kung naka 3rd ka at slow down, you can drop to 1st directly. Maraming permutations yan. Basis talaga is dapat yung engine note mo ay hindi strained pakinggan.
October 4th, 2010 04:07 PM #19
ganito sa akin,
mabilis ang takbo at nasa 5th gear ako;
meron tumawid at kailangan kong bumagal; tapak lang sa brakes then hintay kung kailangan mag full stop or continiue di pa naman mamamatay ang makina, kung kailangan full stop tapak na rin sa clutch for full stop; kung clear na depende sa situation kung pwede pa rin ang speed ko sa 5th gear tapak na lang sa gas para bumilis uli, kung mabagal na change ka na sa aproprriate gear then proceed na ulit.
- Jun 2010
- 354
October 4th, 2010 11:32 PM #20mas malakas ba sa gas ang engine break? or masama ito sa makina? kasi lagi ko ito nagagawa kung baga nasanay yung paa ko
How much room do you have between the battery terminals and the hood seeing the the 3SM is much...
