Results 1 to 10 of 11
- Dec 2009
- 13
November 30th, 2012 06:31 PM #1hello,
Who among you guys owning Ford escape that has already replaced their crankshaft pulley (harmonizing shaft) ?
Shops who has expertise, as wrong reassembly will destroy engine....
Thanks in advance
- Dec 2009
- 13
January 8th, 2013 11:58 AM #2hey peeps..
Just to share with you to all Escape owner from 2004 to 2007 models--
I had my escape replaced my crankshaft pulley at MazFord banawe c/o of Chris -- labor more expensive than the actual item replaced. I had to banked on their expertise ( 10 escapes crankshaft pulley successfully replaced ) as it requires special know how. This pulley cannot be pulled out and put back without causing timing issue problems after.
Found out all my engine support are busted too ( 94K odometer ) thus Chris had it replaced for me too.
Symptom of such faulty parts --
1. squeking sound from engine bay ( from tensioner and fan belt )
2. engine vibration when DRIVE is engaged while holding brake pedal; aircon is turned ON
- - - Updated - - -
- Feb 2011
- 49
January 15th, 2013 08:47 PM #3Hi Bro. How did you know which parts need to be replaced? Did you have you car checked at the CASA first? How much did everything cost you?
Thanks!
- Dec 2009
- 13
January 18th, 2013 02:39 PM #4It was trial and error at 1st --
The squeking sound when I do hard acceleration ( ACU turned On ), I replaced the belt tensioner. It went away for awhile then came back again forcing me to replace tensioner and belt at the same time. After a few months, the same squecking sound again so I drew a marker ( chalk ) on the crankshaft pulley to see if outer pulley and inner pulley does not slide from each other and found it it does thus the final replacement for this part. MazFord from Banawe gave me that advise. However, the damage is done, so I had to replace again, tensioner and belt and finally the pulley.
Cost -- tensioner ( replacement ) 3.3K
belt -- 3.5 k
crankshaft pulley ( original ) 5.5K
labor for replacing pulley 5.5 K ( MazFord mechanics )
Labor for engine support replacement ( all four ) .3.3K ( i used replacement parts,7 k total +3.3 labor ). CASA quote for this reach 30 K so I went back to Mazford instead.
- Feb 2011
- 49
- Jun 2005
- 153
January 22nd, 2013 03:32 PM #6nagpareplace na ako nyan crankshaft pulley, 2.1k , tensioner 900 pesos, sa recto ako bumili lahat ng parts, plus 400 pesos ang labor, kumpare ko kasi yun mekaniko, ireretiming uli sya pagbalik, binuksan pa nga namin yung valve cover para masilip yun position. saka meron sya mark para doon sa crankshaft sensor, dahil hindi magiistart ang makina kapag mali ang position ng crankshaft pulley. sa recto po maraming dealer ng ford dyan, mura rin.
- Dec 2009
- 13
January 23rd, 2013 05:29 PM #7May I know what model is your escape sir ( year ) ?
2.1K for the pulley is very very cheap. Sabi kc sa Mazford..walang replacement part nito...original talga kaya kinagat ko 5.5 K na pulley
- Jun 2005
- 153
January 23rd, 2013 08:49 PM #8sa Bestford trading ko nabili sir sa benavidez recto, dealer sila ng mga ford parts, made in thailand yun nakalagay sa box, yung tensioner, bearing lang binili namin, 900 yata. sa recto sir, napakaraming ford dealer sa racto ,nandyan sila bestford , mustwin, nemerson, winter, 04 yun escape ko sir. yung belt gates pala ginamit namin us made, 700 to 900 yata kuha ko. last august lang yan 2012.
- Dec 2009
- 13
January 24th, 2013 12:13 PM #9Thank you sir.. next time, sa Recto na ako pupunta.... 94 K na mileage ng auto ko so I expect marami pa bibigay dito para palitan.
Ung tensioner mo at bearing, mag kaiba ba sya na piyesa ?
- Jun 2005
- 153
One can only hope.
