Results 1 to 9 of 9
- Jun 2006
- 430
November 22nd, 2012 05:41 PM #1To all the TDCi gurus I have a stupid question... My girlfriend's car is due for an oil change...
What type of oil is best for the TDCi's?? Synthetic?? Semisynthetic??? Mineral???
All inuts welcome!!! Thank you!!!!
November 22nd, 2012 05:53 PM #2
Hi,
Use a CI-4, CJ-4 API rated Motor oil. Since its a diesel plus its turbo charged you need maximum protection possible.
Here are few of my recommendations for you:
Budget Package - prices of these oil range from 197-350 per liter
1. Delo Gold 15w40 - available at most local auto supply, or caltex station. ranges from 197 to 230 per liter
2. Delo God Ultra 15w40 - available at most local auto supply, or caltex station. ranges from 197 to 230 per liter
3. Mobil Delvac MX 15w40 - easily available at any DIY shop in malls. Ace Hardware, Dept Store, hardware section. (239 to 249 per liter, if there is a SMAC sale, less 10% pa)
4. Top 1 Synthetic Diesel Oil 15w40 - available at local auto supply.
5. Zic Up - good reviews are all i've heard so far from this oil.
Mentioned oils above have superb additive package. These offers superior protection to your engine without burning your pocket. bang for the buck oils if you ask me.
600-700 per liter range
1. Motul CDRI specific 10w40 Motor Oil - 600 per liter at A+
2. Royal Purple - you cant go wrong with this, except the price is a bit on the steep side. 700+ per liter
3. Mobil 1 - same as RP. Steep pricing
Last but not the least, make sure you use a good OIL FILTER. Good filtration is the key to extended oil change interval and clean engine internals. The cleaner your oil is the better. Avoid like plague VIC, Fram, OEM.My reco would be Baldwins, Fleetguard, Wix, Donaldson, (good for 10,000KM to 12,000KM)if you cant find any of the mentioned fleet service filter a good over the counter filter would be Bosch. ( good for 5,000KM to 6,000KM)
Possibly, depending on the year of your TDCI Badlwin BT223 / B7491/ can be used.
Ping me if you have any other questions.Last edited by bayen; November 22nd, 2012 at 05:59 PM.
- Sep 2012
- 607
November 23rd, 2012 10:58 AM #4Royal Purple HPS with synerlec technology 560 or 570 pesos per quart and mobil1 Turbo Diesel 5w40 fully synthetic 440 per quart ang bili ko sa makati.
- Jun 2006
- 430
November 24th, 2012 04:30 PM #5Thanks for all the inputs!!!
Now where can I get hold of those Baldwin filters???
November 24th, 2012 05:10 PM #6
Tsikot Member Rank 3
- Dec 2002
- 636
April 3rd, 2013 07:08 PM #7The Focus 2.0L Tdci engine is specified for 5w30 Acea A1/B1/A5 oil.
The oil filter is a cartridge type, not spin on. Does Bosch or Baldwin have these?
A friend used Castrol diesel 15w40 oil, the low oil pressure warning light would come on even when hot and with oil at the right level.
Think it would be better to stay close to a 5w30 or 10w30 synthetic oil with the right Acea rating.
Not sure if the 2.0L Tdci has a DPF in local models but that's probably why a low ash oil is specified.
The Ford spec oil mentions low HTHS value (<3.5) also, but this doesn't help an engine with a turbo.
- Jun 2018
- 11
June 18th, 2018 08:10 PM #9
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
