Results 5,191 to 5,200 of 7777
- Jul 2016
- 939
April 2nd, 2017 12:45 AM #5191
- Jul 2016
- 939
April 2nd, 2017 12:48 AM #5192
April 2nd, 2017 07:27 AM #5193
- Jul 2016
- 939
April 2nd, 2017 08:05 PM #5194Eto lang sir gamit ko: PBC-12 model. Yes, direct lang sa car. I use this when working with forscan para di nakabukas engine.. ACC on lang.
Battery Charger | Panther Electrical
- Jun 2010
- 706
April 2nd, 2017 09:19 PM #5195Sir janemar, ano bago sa forscan? Meron ka ng auto start?
Sent from my ASUS_T00J using Tapatalk
April 2nd, 2017 09:27 PM #5196
So alternator gets turned off (technically detached from the drive belt) if the battery is full to ease the load on the engine. In effect more power can be derived from the engine which becomes more pronounced at full throttle
Eventually when the battery goes low, the alternator is engaged again to charge the battery to restore the lost energy from all its electrical and electronics load
Ok i got it
I have seen the stock ford battery at the car show earlier
Sent from my GT-P3110 using Tsikot Forums mobile app
- Jul 2016
- 939
April 3rd, 2017 10:57 AM #5197
April 3rd, 2017 11:08 AM #5198
^fast charge is another nifty feature, i see
The faster the battery charge fully the sooner the alternator can be unloaded from the engine
This thing reminds me of an electronic circuit for charging battery and it employs an electronic component known as SCR (silicon controlled rectifier) to control the engagement of the alternator
With higher voltage to charge faster i think there is a way to tune this type of alternator to a regular battery with a high current voltage regulator that produce a lower voltage than the stock regulator. This will just engage the alternator more frequently and stress out the engine
To completely disable the smart alternator is to trick the sensor into thinking that the battery is always low by feeding the sensor a constant voltage by disabling the SCR circuit and stepping down the output of the voltage regulator so as not to damage a regular battery. This way the engine is stressed all the time
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; April 3rd, 2017 at 12:00 PM.
April 3rd, 2017 12:11 PM #5199
April 3rd, 2017 12:46 PM #5200
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
