Results 1 to 2 of 2
- Apr 2008
- 112
October 20th, 2013 10:18 AM #1Good day Sirs,
I have a 2005 ford focus sedan, 1.8 petrol engine. Tried scanning with an obd scanner and came up with these codes, also did a bit of research over net so i tried to clean the flaps and changing the already hardened vacuum hoses but to still no avail. Usually would not create any problems at the start but when it warms up a bit, i would have shutters and jolts when i decelerate. There would also be times that even if i press the accelerator, there would be a slight hesitation on power, would appreciate any tips or suggestion if already came across this problem.
Thanks ^_^
- Jan 2008
- 17
November 17th, 2013 05:21 PM #2Happened to me. Replaced acutator. It was stuck-up na. No torque when accelerating fron stop. Speedyfix in San Juan did it.
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
