Results 6,451 to 6,460 of 7178
- Oct 2013
- 78
September 9th, 2014 07:05 AM #6451
- Nov 2009
- 3,507
September 9th, 2014 11:34 AM #6452When you say bearing failure, there could only be two possible results - a loss of power (when impeller/blower got stucked or noise when destroyed), and oil breaching your intake or exhaust resulting to smoke..
Any of the symptoms described (smoke, permanent loss of power) were not present from what i read, all symptoms described here are intermittent loss of power so it could be just boost settings or a leak in IC piping..There is a boost sensor in the intercooler that shutdown fuel delivery when it senses overboost condition, hence limp mode. Also there is what they call FPRV fuel rail pressure relief valve and sensor that shuts also fuel delivery when over pressure in the rail is detected.
It might be helpful if somebody could check if the IC piping baloons when Turbo is boosting.
- Dec 2010
- 336
September 9th, 2014 12:11 PM #6453A bearing failure doesn't mean the turbo will stop rotating. It is not using ball bearings that when damaged it will seize.
It is using a bushing type bearings. Bearing failures on this type of bearings will only scour the bearings damaging its smooth surface lining or damaged to the shaft of the turbo causing pittings and so on.Unless otherwise oil flow is interrupted it will surely cause a seizure.
So power is still available but with that obvious noise.
- Nov 2009
- 3,507
September 9th, 2014 12:27 PM #6454A scored bearing could eventually leak oil, or worse damage the blower due to vibrations.
Sleeved bearing is not immune to seizure. Remember that turbo shaft is cooled by the same motor oil and what happens when it leaks or coke, it forms a varnish seizing the shaft, hence seizure..
- Dec 2010
- 336
September 9th, 2014 12:53 PM #6455In the long term, yes! coking will eventually lead to bearing failures. But thinking, the engine is new, and coking may not be at all present yet. The only thing I think why this new engine t/c fails because of the overloading of the bearing due to overboost. And why overboosting happens?
- Nov 2009
- 3,507
September 9th, 2014 01:19 PM #6456Overboosting due to VNT failure, failed to fully open on WOT?
AFAIK the only restriction is before the EGR valve which is the air-intake shutoff valve, purpose of which is to shut the air preventing engine vibrations due to self detonation of extra fuel everytime engine is turned off.
Just my thoughts, but then again were just guessing. Lets wait for the actual diagnosis and see what really went wrong with the turbo. It would help if some motorhead owners experiencing these probs could actually share some DIY intitial diagnostic info like boost pressure, rail pressure, etc...
Im actually monitoring this thread for the issues i have to face if ever i will replace my pickup with this ranga.
- Apr 2012
- 1,738
September 9th, 2014 07:38 PM #6457Ganun ba kadami problema yun t6? Planning to buy a 3.2 a/t to replace my fxt, pero parang nakakadiscourage bumili.
Or might as well wait till next year, para sa nisssn np300, saw it in Thailand last week, maganda rin naman.
September 10th, 2014 09:43 AM #6458
Last edited by glenn manikis; September 10th, 2014 at 09:46 AM. Reason: Double post
September 10th, 2014 09:44 AM #6459
Sir question if you are right... Is there a way to just keep it full open all the time?
- Dec 2010
- 336
September 10th, 2014 06:55 PM #6460Sir Glenn, there is no way to keep it full open. It is controlled by ecu.
Posted via Tsikot Mobile App
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
