Results 1 to 10 of 31
- Aug 2007
- 11
August 25th, 2007 05:17 PM #1ano po ang mas nakakaapekto sa performance ng car, torque o power?
2 cars, A and B. both cars same specs (weight, gear ratio, size, drag coeff... basta lahat na).. except car A has greater power but lesser torque, car B has lesser power but greater torque.
August 25th, 2007 05:23 PM #2
high torque - faster acceleration from full stop
high hp - may be slower from full stop but will pull away at higher speeds
August 25th, 2007 11:53 PM #3
In general. Yun na yun.
Horsepower really isn't anything more than a calculation of torque versus engine speed.
Basically, when you say "high power, low torque", all you're really saying is that the engine produces more torque at high rpms than low rpms... and when you say "low power, high torque", it's producing more torque at low rpms than high rpms.
What's really important to the driver is the amount of torque available at all points along the rpm range.
For daily driving, more low range torque is better, because, like BB says, you have faster acceleration from a full stop.
For racing, you don't use low rpms. You use primarily high rpms, so a car with more high end horsepower (in other words, a torque curve shifted towards higher rpms) will allow you to accelerate faster at higher speeds.
Tsikot Member Rank 4
- 2,719
August 26th, 2007 01:24 AM #4What if Car A have diesel engine and Car B have gasoline engine but both have same max Hp and max torque?
Obviously, they have different torque/hp curves to reflect their engine characteristics.
So assuming other things equal (losses, drag, weight, etc),
1. Who will reach 100kph first?
2. Who will reach 1km first?
3. Who will reach 10km first?
4. Who will reach 100km first?
My answer: Car A (diesel) on all counts because it would out-accelerate Car B during first few seconds and its initial lead distance would be maintained by the time they both reach their equal top speeds (remember, same max Hp, same losses, same drag, same weight, same etc).
Whaddya think?
edit: Let me just add equally skilled drivers, say Niky.Last edited by kinyo; August 26th, 2007 at 01:40 AM.
August 26th, 2007 03:08 AM #5
That depends on the powerband and the driver's good use of this. Powerband is a different dimension to consider. The diesels can be slow off the line unless you have turbochargers (just like in the BMW 530d with one small and one large to compensate for lag)...
August 26th, 2007 06:36 AM #6
you need HP for top speed.
you need torque for quick 0-100 acceleration.
bottom-line: you need best of both.
but if I had to choose best of one for everyday driving, I vote torque.
but torque band should be best at low rpm. para hindi pansin yung sound fx at the same time the acceleration is awesome. meaning, low profile, yet fast...Last edited by rion; August 26th, 2007 at 12:45 PM.
- Aug 2007
- 246
- Aug 2007
- 246
August 26th, 2007 08:40 AM #8regarding car performance, both torque and hp affect it although more in adverse or vice versa effect. cars with good torque will usually take off faster from a standing start. those with higher hp but low torque will need longer roads to build up speed. engine size and transmission also play a big factor.
good example will be the 1600 civics and corollas from the 90's, the rollas would usually pull stronger during the lower rpm range but then the civic will catch up once the rpm's start to build up.
main reason is that rolla engine blocks have longer strokes for better lower rpm torque but they have lower rev limits and compression ratios, limiting power production in the higher rpm range. i have a friend who had the head of his corolla shaved to give the engine a higher compression ratio then a full free flow exhaust allowed to engine to rev a lot higher. if you happen to be drag racing in libis aound year 2000, this is the flat black corolla that could smoke civics.
civic engine blocks on the other hand have shorter strokes, it needs to rev high in order to produce power but generally lack torque in the lower rpm range. good thing hondas are generally lighter kya hindi kailangan ng big torque sa low rpm. and mas efficient din ang transmission ng honda kaya konti lng ang power loss from the engine to the wheel.
big engines are another story. they do not need to be revved high bcoz they already develop good torque and power even from low rpms. this is due to the sheer volume of air and fuel that combusts in the chamber with each cycle of the engine. ang pinaglalaruan na lng nila ay yng transmission and gearing in order to effectively transfer the power to the wheels and carry the weight of the vehicle.
newer engines though are totally different. almost all new engines now have valve timing technology and advanced ecu's of some sort to manage power production, output and fuel efficiency. usually displacement and rev limit n lng ang responsible sa final output ng engine.
hope this helps mga pips.
- Jan 2007
- 2,326
August 26th, 2007 06:22 PM #9Nalilito pa din talaga ako dito. Ang impression ko kasi sa torque from when I was in HS ay 'lifting power'. At the time, I just projected it as 'pulling' power pagdating sa engines. Noon, ang mga diesel ay mabagal umarangkada pero malakas bumatak at ang dahilan ko noon ay dahil low HP, high torque. Doon ko din napapaliwanag na pag mas mataas ng malaki ang torque ay mas mahirap pigilan ang pag-arangkada.
Kaso ngayon, ang mga diesel ay malaki na ang binilis sa arangkada. Ano ba ang nangyari? Baka naman kasi HP ang tumaas sa diesel RELATIVE sa torque? Kasi dati nang mataas ang torque ng mga diesel di ba? Pero mabagal sila umarangkada noon?
August 26th, 2007 06:32 PM #10
mag bigay na tayo ng real world examples:
2.0 focus: gas at diesel..(di pala pwede--matic ang gas, manual ang diesel!) iba pa:
1.6L gas matrix-manual(meron nito) at 1.5Lcrdi matrix......
1.4L getz-manual vs 1.5crdi-vgt getz
eto pa: kia carens 2.0gas vs 2.0crdi-vgt-->parehong semi-auto lang mga yan..
more torque * low rpm-->advantage on everyday and emergency situations...Last edited by alwayz_yummy; August 26th, 2007 at 06:42 PM.
I feel the same way. Not a fan.
2022 Mazda BT-50 (3rd Gen)
