Results 1 to 10 of 14
- Jul 2007
- 27
July 22nd, 2010 10:25 AM #1Mga sir newbie :newbie: lang po ako about sa sasakyan,
tanong ko lang po kung magkano cost estimate in changing my timing belt? Pwede ba siya magawa sa bahay o kailangan siya dalhin sa talyer nang mekaniko po mismo? Mga ilang oras po o araw ang pagpapalit nito?
Maraming salamat po in advance and more power....:rockon:
- Mar 2010
- 58
July 22nd, 2010 10:29 AM #2I don't know how much the timing belt exactly costs, but it depends per car. I know its starts around 5k+labor+++ depends on the car. If I'm not mistaken. I just recently had my car overhauled because the timing belt broke (valves got bent, serious internal damage).
You should have it fixed with a mechanic. I know Rapide changes timing belts and it may take a while. Not a 1-2 hour job. It takes a while before they can get into the timing belt. They gotta dig deep and remove a lot of stuff.
- Mar 2008
- 174
July 22nd, 2010 12:06 PM #3Ito dapat kasabay ng timing belt change, usually 800 - 1.2k pesos labor nyan.
timing belt
tensioner bearing
waterpump
camshaft oil seal
crankshaft oil seal
- Jul 2007
- 27
July 22nd, 2010 12:06 PM #4Maraming salamat po sir sa reply. Ang sa akin naman po di pa naman siya putol kaya lang gusto ko na siyang palitan dahil second hand ko po nakuha yung '97 Honda City ko po and di ko po alam kung kelan po napilitan nang previous owner yung timing belt (my bad di ko tinanong
To avoid much bigger cost pag naputol yung timing belt gusto ko na po sana siya palitan preventive measure na din kumbaga.
Mga sir any feedback of how much the installation of new timing belt will cost me, kasama na din yung labor doon po???
Maraming salamat po and more power....
July 22nd, 2010 12:14 PM #5
opinion lang, dont go to rapide... dami na horror stories diyan.
sir wave, punta ka sa pasay and look for dondon, mura lang labor sa kanya. siya nagpalit ng timing belt ko then mura pa pyesa sa car power. palitan na lang lahat ng seals and water pump para isang bukasan na lang.
- Jul 2007
- 27
July 22nd, 2010 12:27 PM #6Noted ko po yung rapide sir dami ko nang nabasa sa mga thread dito about their horror stories with rapide... Maraming salamat sir
Ahhh kaya pala ang daming papalitan sabay-sabay para isang bukasan na lang nang makina... now gets ko na, maraming salamat sirbaguhan pa lang kasi po ako pagdating sa kotse po eh.
Normally mga sir how much it will damage my pocket if all of this will be replaced???
- Nov 2006
- 201
July 22nd, 2010 12:59 PM #7sir we have exactly the same type of car. AT nga lang sa akin, ewan ko sa yo. about a month ago nagpalit ako ng timing belt eto gastos ko:
timing belt orig-1,100 nisparts, banawe tel.7421531 look for arnel
water pump japan-900 nisparts
tensioner bearing japa-650 nisparts
crank/cam shaft orig-250 each nisparts, banawe
labor-1,200 sa kaibigan, 1,800 sa speedyfix, 3,00 sa honda spa
it took half the day for the labor sa kaibigan, 6hrs daw sa speedyfix, whole day sa spa
- Jul 2007
- 27
July 22nd, 2010 03:08 PM #8
- Mar 2010
- 58
- Mar 2010
- 58
July 22nd, 2010 12:58 PM #10Never knew about the Rapide horror stories. Just noticed their service menu that they can. Haha! I had mine changed in AutoPlus (but it was a major overhaul, so i don't know if they would accept a timing belt change service alone.) I'm just pretty confident of what they can do to a car since they're well known in the local automotive industry.
Thanks for the heads-up though!
I feel the same way. Not a fan.
2022 Mazda BT-50 (3rd Gen)
