Results 1 to 10 of 13
October 14th, 2007 05:05 PM #1
Okay ba ang gates na brand? Any comments sa mga gumamit na nito. Thanks
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 15th, 2007 04:15 PM #3
ito usually ni recommend na replacement for oem t-belt ng 4jg2 base sa mga nabasa ko sa forum dito. i bought 1 last year when we planned to chance the tbelt of my father-in-law's bighorn. after sometime while reading more reviews regarding tbelt i change my mind and bought the oem na just to have peace of mind. buti nalang naibalik ko pa yung gates tbelt (hindi pa nagamit) sa walco.
nasa 700 yung gates last year sa walco. yung oem naman 2800 ko nabili sa jayson's.
October 15th, 2007 09:42 PM #4
mcbry UNITTA ba ang brand ng OEM? as per garyq Tbelt - 45119x32 t844 119zb32 21t240
Gates Power Grip (Japan) - Php 700. Original ng Isuzu, UNITTA brand 119zb32 hnbr 122 9-34
Nag google ako searching about UNITTA brand and I found out it was made by Gates. http://www.gatesunitta.com/
It means yung brand na Gates na 700 the same lang ng UNITTA brand na ang price is 2,800?
October 15th, 2007 09:48 PM #5
Gates Unitta Asia is the Asia wide joint venture between the Gates Rubber Company and Nitta Corporation. Gates Unitta Asia locations include a trading company branch in Singapore and Taiwan, Unitta company in Japan, Gates Nitta Belt Company in China and Gates Korea (A subsidiary of the Gates Rubber company and Nitta Corporation; a joint venture with Pyung Hwa Industries of Korea) in Korea.
Here is the link:
http://www.gnapco.com/
October 16th, 2007 10:40 AM #6
nap, i forgot the brand ng oem tbelt (8-943806790) pero i think UNITTA nga yun. i'm think iba yung GATES POWER GRIP na replacement than the OEM na UNITTA brand. if isa lang ang nag manufacture nito baka yung isa ay Class A then yung isa ay Class B. i'm not sure though. basta when i inquire sa walco and jayson's same yung binigay nila na OEM kaya yun na kinuha ko.
October 17th, 2007 06:27 PM #7
Nap, Mcbry, LTX and Trooper/Bighorn owners.
SOS from a Isuzu brother from Zamboanga. Trecker1967 is having problems returning his vacuum lines ever since a lousy carwash. If you can take a clear picture of the vacuum routing of your unit's boost actuator to intake diaphram to the 4wd, our brother will be very thankful.
- Oct 2007
- 15
October 28th, 2007 08:47 PM #8
Good day,
Please reply help to trekker_1967*yahoo.com
Thank you very much
- Jun 2008
- 2
April 10th, 2009 07:15 PM #9hi, ask ko lang pano malalaman kung timing chain/gear ang 4jg2 turbo diesel? yung sa dad ko kasi parang di pa niya napapaservice. i've researched a little here and there and ang alam ko lang na clue is kapag maingay yung engine (pero akala ko kasi trademark na ng diesel yun). 3.1 4jg2 siya, 1997 model ata, bighorn. thanks in advance!
April 11th, 2009 12:56 PM #10
pag jdm=timing belt. pag local yung trooper timing gear. mas maingay timign gear.
How much room do you have between the battery terminals and the hood seeing the the 3SM is much...
