Results 1 to 7 of 7
- Oct 2015
- 99
May 28th, 2019 10:11 PM #1May minor wobbling yung tension pulley.
Sa isang innova namen steady yung tension pulley.
Is the pulley broken?
One more thing may kinalaman ren ba yung wobbling sa pag hina ng ac.
I compared yung cooling ng 2 innova namen. Yung isa na no wobbling has colder blowing air.
Mind the volume it might be loud. Eto po yung vid ng pulley.
Wobbling tension pulley innova - YouTube
- Jan 2008
- 4,726
May 28th, 2019 11:53 PM #2
- Oct 2015
- 99
May 29th, 2019 01:19 AM #3Ahh so i need to replace the belt na.
- Aug 2017
- 321
May 30th, 2019 01:19 PM #4Start with the simple things 1st...
1) Check condition ng belt, it may appear to wobble if it is damaged/torn
2) Tensioner pulley, several mechanical parts ito, high chance of wear and tear, yes if it is worn out/broken... It will wobble... Affect your a/c... Affect your water pump... Affect your electrical system
3) Check if your main/crank shaft pulley is solid or have rubber part at its core... If this is worn, it will cause wobbling.
Other pulleys are mostly made of metal + bearings... They also wear out but later than the 2 I mentioned above, albeit they belong to the same system.
- 54,188
May 30th, 2019 01:50 PM #5the video does not, to me, show pulley wobble.
i have forgotten basic innova.
is that an idler pulley, moving up and down or side to side? (this is normal for idlers.)
good pulleys won't wobble, regardless of belt condition.
it might seem to, but a good inspection will prove the otherwise.
there are many failures that can weaken the AC. belt slip is one of them. belt slip has several causes.
do not assume.
one must investigate.
- Aug 2017
- 321
May 30th, 2019 02:10 PM #6Agreed. This is why belts should be checked/replaced regularly... And while the mechanic is at it... All pulleys must be checked.
I experienced seeing my tensioner pulley wobble, only to find out that the main/crank pulley was the one broken.
So, yes investigate, investigate, investigate
May 31st, 2019 02:46 AM #7
Ah, the serpentine belt drive problem, so aptly named this monster! If it's the belt, replace right away. If it's the idler or the tensioner, replace now. If you don't, well you are gonna be so sorry. So many things this serpent can bite if you don't take care of it. A/C compressor, always the first victim to die due to its construction, single bearing pulley on the clutch! Then the water pump, mechanical seals are not designed to handle vibrations. The alternator dies last, 2 bearings on either end makes it tougher than the first 2. Save that p2k now and pay p15k for a new ac compressor later. Your choice.
Just had my comprehensive insurance renewed at PGIC (in-house casa). It was already late when I...
People's General Insurance - no hassle sa...
