Results 11 to 20 of 33
May 6th, 2013 07:01 PM #11
I follow all of these as well (except for num 3 which I was not aware of). I only gas up at 3 stations.
I have the impression that gas stations with mostly public vehicles as customers might not be as diligent or conscientious than those that serve mostly private vehicles.
May 6th, 2013 07:10 PM #12
Thanks for all your inputs .... isip pa rin ako ng isip pero wala na eh... nadisgrasya na ...
Kahit nga mag offer sila ng promo na same price ang Nitro+ sa Fuelsave dun pa rin ako stick sa Fuelsave unleaded... gonna take into consideration muna na iwasan kung sino pinaka luma sa branch nila...
May 6th, 2013 10:09 PM #13
Stick to just one(1) gas station preferably sea oil, uni oil or the big three(3).
May 7th, 2013 01:23 AM #14
May 7th, 2013 10:44 AM #16
Naalala ko yung classmate ko nagpagas somewhere sa pasig may halo daw kaya never na siya nagpagas dun so totoo pala yung may halo.
May 7th, 2013 11:13 AM #17
May 7th, 2013 11:21 AM #18
I think nasa management yan, wala sa brand.
Kung magandang brand walanghiya naman yung may ari wala din.
Gaya ni TS shell siya nagpapakarga.
May 8th, 2013 07:48 AM #19
5. i always refuel in the morning. i read it somewhere that you get more fuel than having it during daytime and evening. as the article explained, cooler temp during the night time makes the fuel denser. pag mainit na daw ang panahon, fuel tends to produce vapor and therefore, the fuel you got when you refuel is mixed with this said vapor. may hangin daw. dont know really if this is really true. wala namang mawawala sa akin kung maniwala ako. i just did it.
May 8th, 2013 08:53 AM #20
[QUOTE=shelu;2135807]5. i always refuel in the morning. i read it somewhere that you get more fuel than having it during daytime and evening. as the article explained, cooler temp during the night time makes the fuel denser. pag mainit na daw ang panahon, fuel tends to produce vapor and therefore, the fuel you got when you refuel is mixed with this said vapor. may hangin daw. dont know really if this is really true. wala namang mawawala sa akin kung maniwala ako. i just did it.[/QUOTE
AFAIK, kaya mas magandang mag pakarga sa umaga kasi kung malamig ang fuel, expanded pa ito, meaning mas konte ang makakarga sa fuel tank puno na agad so less ang babayaran mo in terms of liters (correct me if I'm wrong). Kung mainit na ang panahon, nag-eevaporate na ito while filling up, meaning as
fuel comes out from the nozzle, ung nag-evaporate dumaan na sa meter so babayaran mo yun.
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
