Results 1 to 10 of 12
- Jul 2009
- 251
September 25th, 2010 11:59 PM #1Hello Sir(s)/Ma'am(s),
Magtatanong lang po kung anong auto repair shop marerecommend nyo na knowledgeable sa SR20DE na engine? i'm from taytay and no one seems to know how to repair/proper engine checking dito sa area namin... lagi na lang sinasabi palitan makina kasi mahirap kumuha pyesa / di nila kabisado / etc. etc. (>.< tsk..).
I love my altima and my SR20DE powerplant... ayoko naman sa casa hanggang maari kasi taga ang labor at pyesa nila saka di nila pinapayagan sumama yung owner kapag gagawin yung auto...
Best Regards and Thanks in advance.
- Jul 2009
- 251
September 26th, 2010 12:17 AM #3hahah! yeah, malaking problema is yung erratic idling, and namamatayan na ako minsan on the road. kakapalinis ko pa lang last month ng throttle body at maf. yun pating idle screw ko destroyed na needs replacement, wala somewhere here sa rizal ang meron. (most likely i needed to go to banawe for that...). takot mga mekaniko gumalaw dito ng SR20 eh. hahaha. baka daw masira pa nila lalo di daw nila alam kasi.
September 26th, 2010 12:26 AM #4
September 26th, 2010 07:51 AM #6
you can try contacting these shops:
SPEEDLAB http://www.speedlab.com.ph/contact.php
SPEEDYFIX http://www.speedyfixph.com/
- Jun 2009
- 325
September 27th, 2010 11:30 AM #7
- Jul 2009
- 251
September 28th, 2010 09:30 AM #8Oks thanks po sa mga recommendations.
*nickriingen: Oks pa naman daw yung MAF ko sabi nung nagpalinis ako sa casa eh. pero i'll save your number just in case ^^,m
- Jun 2005
- 3,774
September 28th, 2010 08:40 PM #9Altima with an SR20DE din ang project car ko... actually, car ni GF yun.
nasira ang Fuel Injector nun, so i had to replace it with surplus. 800 lang yun. mahirap talaga maghanap ng parts ng altima. kalimitan order pa at sobra mahal! 20k na din nagastos ko sa altima project ko pero sobrang tipid mode na. eto mga napalitan ko na:
valve cover gasket
front and rear brake pads
reface brake rotors
change injector
suspension c/o zee
engine support c/o m7
clutch master and slave
anyway, you can check you Throttle body and possibly have it cleaned. as for parts, hanap ka sa youngbros sa banawe. dont tell them na altima ang kotse kasi di niila alam yun. you can try saying "bluebird" or SR20 na engine. btw, wala ka din makukuha na distributor cap and engine support nyan...
- Jul 2009
- 251
September 29th, 2010 04:05 PM #10*sirkosero
Thanks sa info sir! talaga 800 lang injectors? sa young bros yun? kasi nung nag papalit ako ng isang injector sa may local shop namin dito sa taytay, sabi niya kumuha daw cia sa banawe at ang presyo nya sakin 2k!!! engine supports and distributor cap oks pa wala pang 1 year pareho.
Salamat talaga sir sa info. ^^,m
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
