Results 1 to 7 of 7
- Jan 1970
- 225
June 8th, 2003 02:46 PM #1Can someone explain this?
What happens if you put regular differential oil? If you do, what happens to the LSD? if it gets damaged from using the wrong lubricant, can it still be fixed?
Ungas, Otep, et al, baka masagot niyo ako...thanks!!
June 8th, 2003 03:38 PM #2
Most LSD's use friction plates/clutch packs (although some use cones) to limit the speed difference between left and right halfshaft (thus the name, LSD).
If the cluctch packs get worn, your most practical solution would be to swap in a new LSD (kahit surplus, most LSDs don't get used to their full potential naman).
Pero I'm not rally sure why you need to use the LSD-specific lubricant. I have always been made to believe that it was for wear prevention.
- Jan 1970
- 219
June 8th, 2003 05:29 PM #3Originally Posted by gulliver
- Jan 1970
- 225
June 8th, 2003 08:33 PM #4OTEP / wolfpack
thanks guys! yes, i can believe it's expensive, and luckily my truck was still under warranty. there's a crazy, crazy story behind it but the important thing is, my lsd is working properly now. whew!
wolfpack
re the oil, what do you think are the special properties of LSD oil that make it different from regular differential oil? i understand its for the clutch pack (in my ranger), but am not sure how the oil works on it. just wondering lang naman.
as for the other item cowboy, sabihin na lang natin my cyberworld is much more enjoyable now, and ignorance for a ordinary motorist like me can often be bliss :wink: gusto ko lang light, friendly advice hehehe...
SALAMAT ULI!
- Jan 1970
- 219
June 8th, 2003 11:41 PM #5Im not a chemical engineer so i really dont know, but suffice to know for me that i have the practical side of the knowledge qoutient hehehehe..... In short i know what its for and ill leave the rest to the know it all types :mrgreen: :mrgreen: :mrgreen: the important thing to me is when im behind the wheel, im in nirvana..............
- Jan 1970
- 225
2025 BYD Seal 5 Premium Review: Best value hybrid at PHP 1.2M? AutoIndustriya - - - - - - - - -...
BYD Philippines
