Results 1 to 8 of 8
November 28th, 2013 09:21 PM #1
Naguluhan na ko. Sabi sa manual ng Accent 95 RON ang recommended fuel. Pero iba pala ang RON (research octane number) kumpara sa Octane rating
Question: sa pinas, octane rating gamit natin. Tama?
Kung tama, ang recommended pala sa sasakyan ko at 91 octane as per RON to Octane conversion? [Archive] - AudiWorld Forums
Pa confirm naman. Salamat
Sent from my iPhone using Tsikot Car Forums
November 28th, 2013 11:01 PM #2
RON is Octane.
RON stands for Research Octane Number. Which is a valid way of measuring octane.
The US uses the AKI, or anti-knock index, which is derived from Motor Octane Number and Research Octane Number.
The only difference between MON and RON is that MON is a more difficult test and is measured with a test engine under load. There is no direct conversion from MON to RON since different blends react differently to both tests. Which is why you can't convert RON to AKI or vice versa.
But none of this matters at all here. Your manual states requirement in RON. All pumps here are labelled in RON. So there's no difference.
November 29th, 2013 12:14 AM #3
Thanks niky. All good info
And now a question. Since phoenix started, i have been refilling there. Owner, my wife's vios and now my accent. Do you think their 95ron unleaded is good?
Vios doesn't mind but am worried with the accent engine knocks of the gamma engine.
My dealer says the new kappa engine is better than gamma, but i want to be on the safe side.
November 29th, 2013 01:27 AM #4
November 29th, 2013 06:17 AM #5
Cost: I can't deny that they are 1.00 - 2.00 cheaper. There are days that they have random discount of 3.00 more on certain hours
Quality: Good thing you pointed out the quality issue. From my experience, owner type jeep, motorcycle and vios have great smooth running engine. But all of them have old engine tech. Do you think with the kappa engine, phoenix will be perfect?
Service: i have yet to visit a rude phoenix station. Very clean washrooms.
November 29th, 2013 02:42 PM #6
I believe that quality issues have more to do with the franchise owners than the company itself. I've visited some big three gas stations that have given me water-contaminated fuel.
As long as you only fill up at one station and have no issues there, no reason not to keep filling up at that station.
November 29th, 2013 02:42 PM #7
November 29th, 2013 03:10 PM #8
I cannot speak for all of the big three, but for one of them, I'm pretty sure that the emergency response and daily monitoring systems established work very well in determining if the site has been contaminated with water, and that the pool of retailers currently running the sites are competent and responsible enough to take the corrective measures whenever unsafe conditions occur that can cause water contamination.
I would also do some research into the final-design-function performance of carbon fiber hoods...
Carbon fiber hood
