Results 1 to 9 of 9
December 14th, 2005 02:38 PM #1
Hi...
i assume sa kahit anong gas station pwde itong gawin...tama ba?
also, may extra bayad ba ito?
does anyone have any advice....na kelangan gawin before mgpa-drain ng fuel tank??
thanks!
December 14th, 2005 02:50 PM #2
well, for sure may extrang bayad, extrang labor yan eh...
why are you draining you tank btw? if papadrain mo might as well have it cleaned.
do a search nalang, may thread na about this.
December 14th, 2005 03:32 PM #3
pa-drain ko kasi madumi ata yng fuel na nakarga before....mdyo pigil ang acceleration at d smooth...this happened after ko mgpakarga kaya yun suspect ko...just got the car from washover kaya ngyn ko lang maiddrain
thanks!
December 14th, 2005 04:01 PM #4
nag-inquire ako a two months ago sa isang motorshop, P1,200 daw ang palinis ng fuel tank for a sedan. dun sa mekaniko ko, P800 naman ang singil nya.
December 14th, 2005 04:33 PM #6
yup either yun o madumi tubig...kasi di naman sya ganun before ko kargahan...
pinta tune-up, carb clean, change air filter ko na ganun parin...
BANNED BANNED BANNED
- 3,790
December 14th, 2005 09:16 PM #7nasa ganun range nga 800-1200 yan sa labas...I diy my gas tank cleaning...nothing to it.. but may eat up your wholeday sa first time kasi ang hindi mo pa kabisado ang sequence ng pagkalas.
Ideally eto ang steps:
1) Drain the tank (I usually use my car na halos 2 liters na lang ang tira). Handa na dapat ang pangbukas ng drain plug (some car requires special tool). I use a batya (metal) to receive the fuel.
2) After draining, I transfer the fuel sa tamang container and keep it away (baka magliyab/sumabog).
3) Remove the sensor/float.
4) Detache the hoses (one going to the engine, another going to the bleeder or gas return from the fuel tank opening).
5) Detache the main hose conecting the tank sa entry ng kargahan ng gas.
6) Remove the bolts that support the tank (usually 4 bolts eto)...some old models naka strap lang ang fuel tank.
7) Remove the tank.
8) Inspect the tank with flashlight (work on an open area with lots of ventilation and no fire around - kahit na yosi lang).
9) If you have time and its sunny, I recommend flashing it with soapy water and fully rinsing it afterwards. Then sun dry it. Sa remaining water inside the tank, I use a paper towel to absorb it all...then sun dry uli.
I use an aircompressor to blow air on all the tubes (hose tube connection) to make sure na walang dumi sa loob ng mga pipes.
10) Sa pagsauli i-reverse mo lang ang sequence from 7 to 1. If completo gamit and time permits, you should be finished in half a day.
Pag hindi maaraw, I flush the tank with the gas that I drained....pero delicado ito...only professionals and risk-takers should do this procedure...pede kasing mag-ignite ang fumes ng gas na ipinangri-rinse mo.
HTH.
December 15th, 2005 11:04 PM #8
Php 300 ata ang binayad ko sa pinsan ni afrasay sa Caloocan para i-drain tanke ko and i-repair yung dents ng rear skidplate. Not sure lang of current prices.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 16th, 2005 08:58 AM #9if that's the same gas you used when you brought the car to have it painted, your gas may be stale na. bad gas (that's been in the car for a long time) will definitely affect your performance.
Mahilig kasi sa profit ang ford. Strategy yan na huwag gawing matibay ang mga parts para maraming...
BYD Sealion 6 DM-i
