Results 1 to 10 of 33
- Apr 2007
- 487
May 20th, 2013 12:36 AM #1Hi guys,
I just want to ask your opinion regarding my Advie.
2006 Adventure diesel, 88k on the odo, due for PMS and change Timing Belt (PMS was last done 5k kms ago), fuel filter last replaced 10k kms ago, air filter last replaced 5k kms ago.
Engine speed seems to be rev-limited to 3k rpm. I can make it run up to 100kph (3k rpm) with no problems. But beyond that, further depressing on the accelerator pedal (as in pedal to the metal) only result to black, black smoke, as if the additional diesel is burnt and then sent to the exhaust directly, no increase in speed.
Can this be a symptom of the timing belt needed to be replaced? As if the timing belt is slipping at high rpm. I know that my unit is due for oil change, but Im somehow doubtful that this is the sole problem.
By the way, I used to mix 2T on my diesel. Do you think it messed up my injectors?
Registered User
- Sep 2011
- 1,313
May 20th, 2013 01:13 AM #2try to check the injection pump sir, , ganyan din naging sakit ng adventure ko, kahit pedal to metal na stock lang sa 3k rpm *100 kph . madumi lang pala ang injection pump ,;)
May 20th, 2013 09:32 AM #3
nung nag drive ako adventure before, nasa 5th gear na 80kph, mdyo hirap na makina if you go 100 up na.
- Apr 2007
- 487
May 20th, 2013 09:57 AM #4Na-max ko kasi dati yung advie ko ng 130kph, around 4200 rpm. So may baseline ako kung may problema yung makina. In the situation I described above, ayaw talaga umangat ng RPM.
- Apr 2009
- 429
May 20th, 2013 10:23 AM #5Use quality air filter. Use OEM. I haven't seen quality replacement air filter for the mitsu advie or the L300. Chances are you're air filter is super dirty or you are using cheap replacement air filter
Registered User
- Sep 2011
- 1,313
May 20th, 2013 03:16 PM #6
May 20th, 2013 03:58 PM #7
Diesel engines need to be cleaned and calibrated every so often. Yours might be blocked. Take it to a competent diesel specialist such as Berrima, Malabon diesel or Central diesel for them to have a look.
- Apr 2007
- 487
May 21st, 2013 10:11 AM #8An update:
I had my oil changed and my air filter cleaned, still the problem persists. Sinubukan ko harurot kagabi, after 2000 rpm, mabagal na ang acceleration nya.
I guess next in line would be to change the timing belt.
May 21st, 2013 10:29 AM #9
- Apr 2007
- 487
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
