View Poll Results: What do you think should be the engine temperature when draining motor oil?
- Voters
- 13. You may not vote on this poll
Results 1 to 10 of 32
Threaded View
- Jan 2007
- 2,575
October 21st, 2019 04:54 AM #24It's not in conflict with what OJ888 said. The manual specifies operating ranges according to ambient temp, but the second rating is indeed for viscosity at 100°C:
Oil viscosity and oil grades | Lubricants
Viscosity is notated using the common classification “XW-XX”. The number preceding the “W” (winter) rates the oil’s flow (viscosity) at zero degrees Fahrenheit (-17.8 degrees Celsius). The lower the number, the less the oil thickens in cold weather.
SAE Multigrade Oils - Viscosities and Densities
For a 7-seater under 1 million, the Suzuki Ertiga is definitely one of the best options — it’s...
Best car worth 1million and below
