Results 1 to 10 of 13
- Aug 2017
- 232
November 12th, 2017 09:03 AM #1Hi,
I had my first PMS (since I bought the 2nd hand 2005 innova a/t gas) last Sept 5 with its odo at 120+k. Mechanic did ATF dialysis, changed oil and oil filter, replaced brake pads and shoe, rotated tires, replaced coolant, added fluid break, replaced spark plugs and fan belt .
I read that I should change oil (and do tune-up? Pls correct me if am wrong) after 3 months or after 5k kms, whichever comes first. Well, 3 months is due on December 5, but I haven't even driven 1k kms... Should I still have my oils changed? Or go to the mechanic even? Pls enlighten... Thanks!
November 12th, 2017 09:21 AM #2
It should be safe to do it every 6,000 km or 6 months, whicherver comes first.
Gasoline engines don’t produce as much by-products as a Diesel engine does.
- 54,188
November 12th, 2017 09:47 AM #3our local metro driving conditions qualify for "severe" driving conditions". our cars spend more timing idling, than making kilometers.
it would probably be wise to follow the "whichever comes first" schedule.
but... Quripot ako.
i follow the "whichever comes last" thing.
i rationalize this by saying to myself, that i don't do idling that much.
kayo, sir.
look back and see, just what type of driving traffic you do.
November 12th, 2017 10:15 AM #4
- Jan 2008
- 4,726
November 12th, 2017 12:07 PM #5
November 12th, 2017 01:45 PM #6
- Aug 2017
- 232
November 12th, 2017 04:36 PM #7I texted my mechanic, sabi nya after 5k kms na daw para sulit... but I think ang tagal pa nun cause I don't drive the Innova every day. Kuripot din ako! Hehe.
I will try after 6 months nalang -- March 2018naka 3k kms na siguro ako by then.
Sent from my EVA-L19 using Tsikot Forums mobile app
- Aug 2012
- 2,767
November 12th, 2017 05:52 PM #8
- Aug 2017
- 232
November 12th, 2017 06:36 PM #9Mechanic used Castrol GLX (gas). Next oil, I might use Zic, but just the semi synthetic. I tried to check pala the oil today, malinis pa naman, pinkish reddish.
November 13th, 2017 05:17 AM #10
from TGPH
http://www.topgear.com.ph/features/c...ef=home_feed_1
Is the eMax 7 battery (Pure EV) a newer blade battery than sealion 6? I know one is hybrid and the...
BYD Sealion 6 DM-i
