Results 11 to 20 of 24
May 31st, 2016 07:07 PM #11
yup, italian tune up. fill up with the best caltex with techron available and run it fast. if it is a manual tranny run it at 4th gear max only (don't shift to 5th) at the fastest speed you can go without getting a ticket. pag pasok pa lang sa expressway walang petik-petik na merge. Hataw agad, floor the accelerator. kaya binahayan ng carbon yang makina ng kotse mo kasi puro city driving ka. at susmaryosep, kung mabilis na sa iyo ang 90kph e garantisado barado na makina mo. parang tao din yan, pag walang exercise kinakapos ng hininga.
- Oct 2008
- 380
- Oct 2013
- 2,537
May 31st, 2016 09:10 PM #13
- Oct 2008
- 380
May 31st, 2016 11:06 PM #14
- Oct 2008
- 380
May 31st, 2016 11:10 PM #15
- Oct 2008
- 380
May 31st, 2016 11:14 PM #16
- Jun 2011
- 134
June 1st, 2016 05:26 PM #17
June 3rd, 2016 10:01 AM #18
too early for the clutch to go....usually higher than 150k or even 200k kms bago palit clutch lalu na kung city driving lang. unless clutch rider ka.
saglit lang, papano mo icoconnect yung ignition coil pack to the spark plug? di bat high tension wire pa rin iyon.
June 3rd, 2016 10:28 AM #20
what they are talking about is COP(coil on plug). this system has an ignition coil per cylinder and it sits directly on top of the spark plug.
the other ignition systems:
distributor type- the oldest and the most commonly used up until the early 2000s
wasted spark system- used on even number cylinder engines, the ignition coil fires two cylinders at the same time(piston mates), one on the event cylinder and the other on the exhaust cylinder
1. with one spark plug wire on the piston mate and the other spark plug directly under the coil
http://www.pakwheels.com/forums/atta...resdefault.jpg
2. with spark plug wires on both piston mates
http://cimg2.ibsrv.net/gimg/www.thir...085b119a4d.gif
coil on plug- one ignition coil per cylinder
1. single strike system- traditional one firing line
http://www.autoditex.com/Knowledge-b...ge002_0008.jpg
2. multi strike- three to five firing lines
http://dtec.net.au/Multi%20Spark%20I...s/image007.gifLast edited by jick.cejoco; June 3rd, 2016 at 10:33 AM.
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
