Results 11 to 20 of 24
    City driving most of the time?
    Carbon build-up lang. Italian tune-up kailangan.
    Drive it like you stole it.
    yup, italian tune up. fill up with the best caltex with techron available and run it fast. if it is a manual tranny run it at 4th gear max only (don't shift to 5th) at the fastest speed you can go without getting a ticket. pag pasok pa lang sa expressway walang petik-petik na merge. Hataw agad, floor the accelerator. kaya binahayan ng carbon yang makina ng kotse mo kasi puro city driving ka. at susmaryosep, kung mabilis na sa iyo ang 90kph e garantisado barado na makina mo. parang tao din yan, pag walang exercise kinakapos ng hininga.
    Oct 2008
    Quote Originally Posted by 7138 View Post
    MT ba ito sir? if it is, pakiramdaman mo, pwedeng nagsisimula ng dumudulas ang clutch.
    if AT, paflush mo ATF, then fill in fresh batch.
    distributor-less engines doesn't need to be manually adjusted, wala ka ng gagalawing distrubutor for the timing.
    the ecu will automatically adjust by itself.
    the least TS can do is, reset the ecu.
    Manual po. So clutch na ba yon?
    Oct 2013
    Quote Originally Posted by african888 View Post
    clutch if too high RPM on high gears (best basis is the direct drive gear ratio of 1:1 which is the 4th gear on a standard 5 speed MT) yet speed is slow or wont accelerate... aka slipping...
    observe your RPMs again and provide feedback
    Oct 2008
    Hhmmm akala ko bka bad gasoline lang. Silver lagi ko gamit. Since me long drive, nag gold ako.
    Oct 2008
    How do i restart the Ecu? Yon ba yong disconnect battery , wait , thwn kabit ulit?
    Oct 2008
    Quote Originally Posted by Stigg ma View Post
    Di ko alm pano describe e. Parang pag nasa 5th gear na ako , tapos hahataw na e parang nasasamid
    Jun 2011
    Quote Originally Posted by box_type View Post
    can you please elaborate, kung walang distributor, san kukuha ng spark mga sparkplugs? o mali lang intindi ko?
    Sir,nka individual coil na kse.kya wala ng hi tension wire.
    May 2009
    too early for the clutch to go....usually higher than 150k or even 200k kms bago palit clutch lalu na kung city driving lang. unless clutch rider ka.
    saglit lang, papano mo icoconnect yung ignition coil pack to the spark plug? di bat high tension wire pa rin iyon.
    Napalitan ba fuel filter? Palinis mo rin gas tank.
    Feb 2009
    Quote Originally Posted by miked View Post
    what they are talking about is COP(coil on plug). this system has an ignition coil per cylinder and it sits directly on top of the spark plug.
    the other ignition systems:
    distributor type- the oldest and the most commonly used up until the early 2000s
    wasted spark system- used on even number cylinder engines, the ignition coil fires two cylinders at the same time(piston mates), one on the event cylinder and the other on the exhaust cylinder
    1. with one spark plug wire on the piston mate and the other spark plug directly under the coil
    http://www.pakwheels.com/forums/atta...resdefault.jpg
    2. with spark plug wires on both piston mates
    http://cimg2.ibsrv.net/gimg/www.thir...085b119a4d.gif
    coil on plug- one ignition coil per cylinder
    1. single strike system- traditional one firing line
    http://www.autoditex.com/Knowledge-b...ge002_0008.jpg
    2. multi strike- three to five firing lines
    http://dtec.net.au/Multi%20Spark%20I...s/image007.gif
Parang kinakapos pag more than 80kph ang speed at paakyat
