Results 1 to 7 of 7
November 1st, 2003 09:26 PM #1
patulong naman, ano ba pagkakaiba nang ordinary diesel engine, CRDI and VGT? I saw this sa brochure ng Hyundai vehicle na I was planning to buy kasi, dun sa chart nila, lumalabas na pinaka fuel efficient yung VGT, although pare pareho ang kanilang engine displacement, pasensya na, kasi ang tagal ko ding inipon yung ipambibili kaya nag sisiguro lang ako, Salamat po.
November 1st, 2003 11:11 PM #2
CRDI means common rail direct injection.
VGT probably means variable geometry turbo.
These two technologies are way different. In short there's no comparison since an engine can have both.
November 2nd, 2003 12:03 AM #3
Pinaliwanag ni Ungas at pajerokid iyan using a Php300,000.00 4M40 engine on a stand. Pero gutom na kasi ako nun. :D
November 2nd, 2003 12:07 AM #4
VGT and CRDi can coexist. CRDi is the method of fuel deliver (common rail direct injection) while VGT is the method of forced induction (air deliver). VGT works by varying the pitch of the blades (parang sa helicopter) in order to optimize the amount of air being force fed into the engine.
November 2nd, 2003 04:07 PM #5
direct injection engines usually produce more power but also more noise and vibration
November 2nd, 2003 07:53 PM #6
on a side note, the 4D56 with VGT is available for thai versions of the Strada.... producing an additional 14 horses.
The subject vehicle in question is a typical four channel ABS/traction controlled system that uses...
ABS and Handbrake Lights Both On
