Results 11 to 16 of 16
January 17th, 2014 10:02 AM #11
Maybe your fuel gauge also has an issue. My gauge before was acting funny wherein I'd tank up and drive around for a good distance without the needle moving at all then all of a sudden, it drops. It turns out my fuel float was the culprit so in your case, you need to go through a process of elimination to properly detect what may be wrong with your vehicle.
A. Injector pump issue
B. Dirty nozzles
C. Fuel gauge issue
D. Fuel float issue
E. Contaminated tank
When was the last time you had the fluids changed such as the oil? If you drove it out of the dealership and haven't changed anything, chances are, the oil inside is from 2005! (That is, if what the agent says is true.) And since that vehicle was just stuck, the fuel inside the tank would have gone bad. Adding the 2T might have loosened some of the sludge / deposits which might mean that your fuel filter would be blocked. If you ask me, you need a mechanic to do a thorough check on it.
- 36
- 36
January 20th, 2014 12:12 AM #13By the way sir K.I.L.L. where shop did you bring to do your fuel float? TIA
January 20th, 2014 12:29 AM #14
- 36
January 20th, 2014 06:06 PM #15
- 36
January 28th, 2014 05:10 PM #16Mga paps panatag na loob ko for this issue, i did a full tank method test & the result is good 11km/liter for a long drive. Its not bad considering 7 adults, 3 kids and 1 baby plus baggage e way up to tagaytay.
Next test yung city driving naman :thumbup:thanks po sa lahat ng comments & suggestions
I feel the same way. Not a fan.
2022 Mazda BT-50 (3rd Gen)
