Results 1 to 1 of 1
July 10th, 2013 02:28 PM #1
540RAT - Tech Facts, NOT Myths <<<click and read for full details
1. 5W30 Pennzoil Ultra, API SM synthetic = 115,612 psi
I have not been able to find this oil with the latest API SN certification. The bottle says, “No leading synthetic oil provides better wear protection”. For once, a product’s hype turns out to be true. And this oil provides MORE THAN TWICE as much wear protection as the lowest ranked oil on this list.
zinc = 806 ppm
phosphorus = 812 ppm
moly = 66 ppm
calcium = 3,011 ppm
TBN = 10.3
2. 5W30 Oil Extreme, API SM conventional = 110,286 psi
The Company claims this oil contains their proprietary formula of calcium petroleum sulfontate EP (Extreme Pressure) technology that is NOT found in any other motor oil. They also claim that it will provide 5 to 7 more HP, 7 to 10% better fuel mileage, cut engine wear in half, and will extend drain intervals two or three times safely. This oil is endorsed and promoted by Tech Author David Vizard. And he was so impressed by this oil’s performance that he also became a share holder in the Company. The “Dynamic Wear Testing Under Load” performed here, supports their claim regarding wear protection. This product’s hype about that, turns out to be true.
zinc = 765 ppm
phosphorus = 624 ppm
moly = 52 ppm
calcium = 7,652 ppm
TBN = 23.2
3. 10W30 Lucas Racing Only synthetic = 106,505 psi
zinc = 2642 ppm
phosphorus = 3489 ppm
moly = 1764 ppm
calcium = 2,929 ppm
TBN = 9.0
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
4. 5W30 Mobil 1, API SN synthetic = 105,875 psi
zinc = 801 ppm
phosphorus = 842 ppm
moly = 112 ppm
calcium = 799 ppm
TBN = 7.5
5. 0W30 Amsoil Signature Series 25,000 miles, API SN synthetic = 105,008 psi
zinc = 824 ppm
phosphorus = 960 ppm
moly = 161 ppm
calcium = 3,354 ppm
TBN = 11.4
6. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phosphorus = 1518 ppm
moly = 784 ppm
calcium = 1,607 ppm
TBN = 4.4
7. 5W50 Motorcraft, API SN synthetic = 103,517 psi
zinc = 606 ppm
phosphorus = 742 ppm
moly = 28 ppm
calcium = 1,710 ppm
TBN = 6.7
8. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phosphorus = 1544 ppm
moly = 3 ppm
calcium = 2,707 ppm
TBN = 7.6
9. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phosphorus = 1112 ppm
moly = 162 ppm
calcium = 2,664 ppm
TBN = 7.4
10. 5W30 Pennzoil, API SN conventional, yellow bottle, with Oil Extreme concentrate added in = 100,252 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi, and is ranked 53rd. But, with the concentrate added, its wear protection capability “WENT UP A WHOPPING 30.2%”. This is the first additive I’ve ever tested that actually worked as advertised.
zinc = 970 ppm
phosphorus = 749 ppm, this value is 91 ppm lower than the basic oil because the concentrate has less phosphorus in it, which dilutes the overall ppm count of the mixture.
moly = 285 ppm
calcium = 4,443 ppm
TBN = 18.8
11. 5W30 Chevron Supreme, API SN conventional = 100,011 psi
This oil only cost $4.29 per quart at an Auto Parts Store when I bought it.
zinc = 1018 ppm
phos = 728 ppm
moly = 161 ppm
12. 5W20 Castrol Edge with Titanium, API SN synthetic = 99,983 psi
zinc = 1042 ppm
phos = 857 ppm
moly = 100 ppm
titanium = 49 ppm
13. 5W30 Pennzoil Platinum, API SN synthetic = 99,949 psi
zinc = TBD
phos = TBD
moly = TBD
14. 20W50 Castrol GTX ,API SN conventional = 96,514 psi
zinc = 610 ppm
phos = 754 ppm
moly = 94 ppm
15. 30 wt Red Line Race Oil synthetic = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
moly = 1235 ppm
16. 0W20 Mobil 1 Advanced Fuel Economy, API SN synthetic = 96,364 psi
zinc = 742 ppm
phos = 677 ppm
moly = 81 ppm
17. 5W30 Quaker State Ultimate Durability, API SN synthetic = 95,920 psi
zinc = 877 ppm
phos = 921 ppm
moly = 72 ppm
18. 5W30 Castrol Edge with Titanium, API SN synthetic = 95,717 psi
zinc = 818 ppm
phos = 883 ppm
moly = 90 ppm
titanium = 44 ppm
19. 10W30 Joe Gibbs XP3 NASCAR Racing Oil synthetic = 95,543 psi
zinc = 743 ppm
phos = 802 ppm
moly = 1125 ppm
20. 5W20 Castrol GTX, API SN conventional = 95,543 psi
zinc = TBD
phos = TBD
moly = TBD
NOTE: Oil numbers 19 and 20 were tested weeks apart, but due to the similarities in their wear scar sizes, their averages ended up the same.
21. 5W30 Castrol GTX ,API SN conventional = 95,392 psi
zinc = 830 ppm
phos = 791 ppm
moly = 1 ppm
22. 10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
moly = 52 ppm
23. 5W30 Havoline, API SN conventional = 95,098 psi
zinc = TBD
phos = TBD
moly = TBD
24. 5W30 Valvoline SynPower, API SN synthetic = 94,942 psi
zinc = 969 ppm
phos = 761 ppm
moly = 0 ppm
25. 5W30 Valvoline Premium Conventional, API SN = 94,744 psi
zinc = TBD
phos = TBD
moly = TBD
26. 5W20 Mobil 1, API SN synthetic = 94,663 psi
zinc = 764 ppm
phos = 698 ppm
moly = 76 ppm
27. 5W20 Valvoline SynPower, API SN synthetic = 94,460 psi
zinc = 1045 ppm
phos = 742 ppm
moly = 0 ppm
28. 5W30 Lucas, API SN conventional = 92,073 psi
zinc = 992 ppm
phos = 760 ppm
moly = 0 ppm
29. 5W30 O’Reilly (house brand), API SN conventional = 91,433 psi
This oil only cost $3.99 per quart at an Auto Parts Store when I bought it.
zinc = 863 ppm
phos = 816 ppm
moly = 0 ppm
30. 5W30 Maxima RS530 Synthetic Racing Oil = 91,162 psi
zinc = 2162 ppm
phos = 2294 ppm
moly = 181 ppm
31. 5W30 Red Line, API SN synthetic = 91,028 psi
zinc = TBD
phos = TBD
moly = TBD
32. 5W20 Royal Purple API SN synthetic = 90,434 psi
zinc = 964 ppm
phos = 892 ppm
moly = 0 ppm
33. 10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi
zinc = 1221 ppm
phos = 955 ppm
moly = 99 ppm
34. 10W60 Castrol TWS Motorsport, API SJ conventional = 90,163 psi
This oil is manufactured in Europe and is sold in the US for BMW models M3, M5, M6, Z4M, and Z8.
zinc = TBD
phos = TBD
moly = TBD
35. 5W20 Valvoline Premium Conventional, API SN = 90,144 psi
zinc = TBD
phos = TBD
moly = TBD
36. 5W30 Havoline, API SN synthetic = 89,406 psi
zinc = TBD
phos = TBD
moly = TBD
37. 30 wt Castrol Heavy Duty, API SM conventional = 88,089 psi
zinc = 907 ppm
phos = 829 ppm
moly = 56 ppm
38. 20W50 LAT Synthetic Racing Oil, API SM = 87,930 psi
zinc = TBD
phos = TBD
moly = TBD
39. 5W30 Valvoline Nextgen 50% Recycled Oil, API SN conventional = 87,563 psi
zinc = 947 ppm
phos = 778 ppm
moly = 0 ppm
40. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
moly = 24 ppm
41. 5W20 Pennzoil Ultra, API SM synthetic = 86,034 psi
zinc = TBD
phos = TBD
moly = TBD
42. 15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O = 85,663 psi
zinc = 1615 ppm
phos = 1551 ppm
moly = 173 ppm
43. 5W30 Castrol Edge w/Syntec, API SN (formerly Castrol Syntec) black bottle, synthetic = 85,179 psi
zinc = TBD
phos = TBD
moly = TBD
44. 5W30 Royal Purple API SN synthetic = 84,009 psi
zinc = 942 ppm
phos = 817 ppm
moly = 0 ppm
45. 20W50 Royal Purple API SN synthetic = 83,487 psi
zinc = 588 ppm
phos = 697 ppm
moly = 0 ppm
46. 20W50 Kendall GT-1 High Performance with liquid titanium, API SN conventional = 83,365 psi
zinc = 991 ppm
phos = 1253 ppm
moly = 57 ppm
titanium = 84 ppm
47. 5W30 Mobil 1 Extended Performance 15,000 mile, API SN synthetic = 83,263 psi
zinc = 890 ppm
phos = 819 ppm
moly = 104 ppm
48. 0W20 Castrol Edge with Titanium, API SN synthetic = 82,867 psi
zinc = TBD
phos = TBD
moly = TBD
49. 5W30 LAT Synthetic Racing Oil, API SM = 81,800 psi
zinc = 1784 ppm
phos = 1539 ppm
moly = 598 ppm
50. 5W30 Peak, API SN synthetic = 80,716 psi
zinc = TBD
phos = TBD
moly = TBD
51. 5W30 Edelbrock “Cat-Safe”, API SM synthetic = 78,609 psi
This oil is made for Edelbrock by Torco
zinc = 924 ppm
phos = 659 ppm
moly = 28 ppm
52. 15W40 ROYAL PURPLE Diesel Oil synthetic, API CJ-4 /SM, CI-4 PLUS, CH-4, CI-4 = 76,997 psi
zinc = TBD
phos = TBD
moly = TBD
53. 5W30 Pennzoil, API SN yellow bottle, conventional = 76,989 psi
zinc = TBD
phos = TBD
moly = TBD
54. 10W40 Chevron Supreme, API SN conventional = 76,806 psi
zinc = TBD
phos = TBD
moly = TBD
55. 5W30 Lucas API SM synthetic = 76,584 psi
zinc = 1134 ppm
phos = 666 ppm
moly = 0 ppm
56. 5W30 GM’s AC Delco dexos 1 API SN semi-synthetic = 76,501 psi
zinc = 878 ppm
phos = 758 ppm
moly = 72 ppm
57. 5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi
zinc = 1252 ppm
phos = 1197 ppm
moly = 71 ppm
58. 5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
moly = 204 ppm
NOTE: This particular bottle of oil was just opened, but was out of a 3 ˝ year old case.
59. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
moly = 2 ppm
60. 5W30 Peak, API SN conventional = 73,690 psi
zinc = TBD
phos = TBD
moly = TBD
61. 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi
zinc = 1519 ppm
phos = 1139 ppm
moly = 80 ppm
540 RAT
Member SAE (Society of Automotive Engineers)
http://540ratblog.wordpress.com/ <click and read for full details
Just had my comprehensive insurance renewed at PGIC (in-house casa). It was already late when I...
People's General Insurance - no hassle sa...
