Results 11 to 20 of 38
- Apr 2014
- 231
April 1st, 2016 02:21 AM #12
- Jan 2015
- 468
April 1st, 2016 02:37 AM #14
hmmm, just check 15w-50 is their regular oil. i am using toyota FS - 5w40. ung semi synth nila 10w-40, ung regular oil 15w-40, ung jurassic oil nila na pinakamura is 15w or 20w-50 ata. pero bihirang casa nagbebenta nito.
i worked with GT CAP group before circa 2008 - 2012 and yeah they are using caltex products for oils kung sa planta kukuha si dealership. so based on my estimate 60 to 70% of the oils they have is from CALTEX. although some dealership(s) (depende pa sa may ari) just got the oil somehwere else na approved ng planta.
- Apr 2014
- 231
April 1st, 2016 03:15 AM #15i googled it & went to toyota casa .. their regular oil with green label is 20w50, their synthetic blend with red labe is 15w50 and their fully synthetic with yellow label is 5w40 ....
my question is, assuming two semi-synthetic oils are rated with the same 15w but differs on the last number (15w40 vs 15w50) .. Does the 15w50 offers better maximum heat protection at operating temperature (40 vs 50) ????
Why is 15w50 thicker than 15w40 when they have the same 15w winter numbers ???
April 1st, 2016 03:25 AM #16
Follow manufacturer recommendation
Yes a 0w50 will protect well for a a racing car or ferraris but they do operate at a higher speed.
Your old engine probably idles more in traffic than anything. Even if you rev it to 4000rpm a 40 weight oil will be good enough to protect your engine...a 50 weight will not have better protection than the 40 weight.
April 1st, 2016 09:02 AM #17
I'm also using Mobil 1000 15W40, and it's way better than 20W50. Every 5,000km oil change, surely, I'm not going back to 20W50.
- Oct 2015
- 1,054
April 1st, 2016 06:27 PM #19Having the same winter numbers only means they should more or less behave the same way during cold starts. The actual oil thickness at operating temps is the 2nd number. Thicker isn't always better, thicker oils get you less fuel economy. Also, with group 1, 2 and 3 oils the bigger the difference between cold and hot numbers, the higher the amount of viscosity improvers. These VI give out eventually and when they do, the oil will behave more like a monograde oil with the hot number viscosity at startup. That's one reason why mineral/semi syn oils should be changed more frequently.
- Jun 2008
- 1,741
April 1st, 2016 09:14 PM #20Bakit mo gusto gumamit ng 50 viscosity rated oil ano yan makina ng barko? Ok ang mataas kung malaki ang clearance ng mga bearing. Opinion ko lang po.
One can only hope.
