Results 1 to 10 of 17
January 21st, 2014 01:42 PM #1
yung car nang tita ko nastuck up for more than 6months. Hindi sya nagamit or nastart paminsan minsan.
Ngayon nung pinatingnan nya sa akin may engine check na sya na umiilawa.
Ano ba ang dapat gawin dito? Usually ano ang naging cause nito? Need ba na nang overhaul eto?
January 21st, 2014 01:50 PM #2
what car, year, model? hirap hulaan but definitely no need for overhaul
January 21st, 2014 01:51 PM #3
ford focus 2008 model.
Change oil can do po ba? Para mawala yung engine check?Last edited by CLAVEL3699; January 21st, 2014 at 01:56 PM.
- Aug 2010
- 86
January 21st, 2014 02:11 PM #4Sir, kung umaandar then pa diagnose. Recommended ung change oil since matagal na nastuck. Pati na rin iba fluids like brake fluid.
January 21st, 2014 02:40 PM #5
baka madumi lang ang TB, MAF and servo.
pero mas maganda pa scan. pero bago ma start siguro, change oil muna.
- Jan 2010
- 367
January 23rd, 2014 09:43 AM #6
June 24th, 2016 04:14 PM #7
Our '08 Kia Picanto was involved in an accident, and when it came out of the shop, the Check Engine Light was constantly on, becoming a friction point between me and the shop. I was quoted P8,000 for an oxygen sensor. I researched on this issue and first tried the removing the battery, and thankfully the the light went out. Hoping it lasts.
- Oct 2009
- 2,271
June 24th, 2016 07:20 PM #8naku bat ganun mga focus.
ung sa bayaw ko .seaman kasi siya kaya minsan lang ma istart ng ate ko sa garahe.ngayon ng dumating siya at gagamitin. may mga naka ilaw na sa dash.ung sa abs naka ilaw.ung mga bintana dati pwede mong buksan sa remote ng sabay sabay pati moonroof.ngayon ung dalawa nalang sa harap bumubukas.
pina check sa casa sensor daw ng sira.paano kaya masisira un napaka dalang gamitin.8k palang tinakbo 3 years at 5 months palang.ung focus.2013 focus S ,.pina reset na sa casa pero ganun parin..
July 14th, 2016 10:33 AM #9
So the Check Engine Light keeps coming back even after we reset the battery on our Kia Picanto. Tried the other DIY measures like checking the spark plugs and gas cap. Surprised that few shops have scanners and those that do charge a pretty hefty price just to read the error code:
1) Bong Baron talyer on Olx - P500
2) Servitek Pasig Kapitolyo - P1,000
3) Speedyfix - P1,500
July 15th, 2016 06:28 AM #10
OK yan si bong baron. tinawagan ko yan 12mn dahil 1st time ko magka CEL error. sabi ko medyo short ako, sabi nya dalhin nalang daw, wala sa scanner sa shop (close narin kasi) pero nilinisan nya yung MAF for free (ito daw kasi common cause). gave him 300 php sa wallet ko ayaw tanggapin. bumalik CEL after 2 km drive, sabi naman nya wag mag alala, balik nalang daw ako sa umaga. sa ka-OC han ko, nanghiram ako scanner sa kaibigan ko. showed him the error, tinuruan nalang ako pano ayusin. at ako pa pinabili ng pyesa, 80php lang dun sa surplus. ^_^
btw if youre near araneta cubao or pasig, may scanner ako baka gusto mo check natin
Toyota Sports 800 (1965 - 1969) behind the man at the start of the video. :nod: I wish car...
2025 Manila International Auto Show
