Results 21 to 30 of 32
August 15th, 2018 07:36 AM #21
Maybe a good mechanic or better yet a good technician. What a shame.
The condition can be observed and diagnosed with an engine analyzer os oscilloscope which we have been using since the seventies. Maybe our automotive schools only train students to be parts replacers😟.
The ignition, fuel and some mechanical symptoms can be seen like an EKG to an experienced physician.
So much of that, ask to have the PCM scanned again, this time record the STFT and the LTFT ( short term fuel trim and long term fuel trim respectively.
- Aug 2018
- 17
August 15th, 2018 08:46 AM #22If only a mazda center is near here i will go and have it scanned but its too far and the car is behaving very bad and i might damage it more travelling that far...
Thanks for the advice and find a shop who knows that fuel trim... they dont even know where to start troubleshooting even they know whats my problem... and now my cat is broken due to using it travelling to find a good shop
August 15th, 2018 01:58 PM #24
I'm wondering if what I'm thinking is next to impossible:
1. Go to Mazda or call and arrange for an appointment.
2. Call a towing service, a carrier that will bring the car to Mazda.
This should cost you about 4,000 Pesos. However, I have the peace of mind that someone from Mazda (hopefully) is competent enough to diagnose the problem.
The premise is, I don't know someone who is good enough to troubleshoot the car in our garage.
- Aug 2018
- 17
August 15th, 2018 02:40 PM #25
August 15th, 2018 03:02 PM #26
I remember back with our CR-V 98, the transmission will engage intermittently until it stopped working. I called the guy from Honda and he arranged for a towing service. After the diagnosis, they recommended to replace the transmission. Price is about 250,000 and I have to wait for at least one month as the said part will be ordered from Japan.
The same guy who brought it took the car to another shop and they gave me the option to replace it with a surplus unit for three days or they buy a repair kit and fix it for at least one week. I opted to replace it.
Right now, I'm building good relationship with the Mazda boys.
I'm off topic again...
- Aug 2018
- 17
August 16th, 2018 01:18 PM #27Finally found a good mechanic... my car really is running very bad like it will die anytym... then i went to this shop and he easily found the problem upon opening the hood... the vaccuum hose is cutted and air leaking... but still after fixing idle is misfiring then changed 1 ignition coil no.4... and everything went fine after.... is it ok changing 1 ignition coil or i should change the 3 more?
- Jan 2008
- 4,726
- Mar 2005
- 703
August 16th, 2018 03:27 PM #29if they're cheap, why not. I had two go one week, replaced them at the CASA, then the other two gave out the following week...just not my luck back then....
Also, just a tip, if the ECU was ever reset by disconnecting the battery. Always do the 20min idle reset, this will re-teach the ECU on the throttle body ICV current performance (quality of air it lets in on idle). Otherwise it'll be doing the relearning process on the road(you'll see the rev going up and down like crazy for the first 100kms...when you're at idle.)
- Mar 2011
- 96
September 5th, 2018 01:05 AM #30
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
