Results 11 to 19 of 19
March 12th, 2012 10:49 PM #11
- Jun 2005
- 3,774
March 13th, 2012 12:07 AM #12what are the benefit/s of having a lower compression? isnt it that a higher compression for gas engine should be better?
- Jun 2009
- 222
March 13th, 2012 01:16 AM #13Specifically for 4d56 pala to.
If the original valve is protruding on the cylinder head, there should be a corresponding recess on the piston head.
If your engine displacement is 2477/4 that will be around 620cc per cylinder.
If your compression ratio is 21:1 the original volume of combustion chamber will be 620cc/21-1 or around 31cc
If you will replace your original cylinder head with recessed type valve and if you will still be using the same recessed piston, you can estimate the change in the volume of combustion chamber as follows:
Intake valve dia = 40mm, volume of recess in CH will be (pie/4*40^2)*(136.5-130), that will be around 8,000mm3 or 8cc of additional chamber.
Exhaust valve dia = 34mm, volume of recess in CH will be (pie/4*34^2)*(136.5-130), that will be around 6,000mm3 or 6cc of additional chamber.
Your new combustion chamber volume per cylinder will now be 31cc + 8cc + 6cc or around 45cc
Your new compression ratio will now be (620+45)/45 or around 15:1.....
March 14th, 2012 01:49 PM #14
thanks for your replies.
here's the scenario: same pistons (& block), same cylinder head....only the valves (maybe cam and springs too) to be replaced if ever. afaik, all 4d56 have the same recess on the pistons. be it NA or turbo versions.
March 14th, 2012 03:12 PM #15
Shouldn't have much effect, then. What will matter is the shape of the cam profile, since I assume those shorter valves are mated to taller buckets and/or different cams.
March 15th, 2012 01:24 PM #16
after some research (of course taking these discussion here too), it (shorter valves) won't physically change the amount of air compressed. the most possible solution for a lower CR are the dished pistons. a lower CR would also mean lower hp/torque but engine will run cooler. problem is no available dished pistons. a double gasket is also unreliable....cancel the plan then.
March 15th, 2012 02:19 PM #17
If the purpose is to lower operating temps, why not just go with a small intercooler? Like maybe a stock side-mount or front-mount from another vehicle. Simpler. Less complicated installation.
March 15th, 2012 05:19 PM #18
March 15th, 2012 07:55 PM #19
Yup... you'll have to add a bit of piping, but it's more easily reversible and less risky than cracking open the engine to change out the cams.
I feel the same way. Not a fan.
2022 Mazda BT-50 (3rd Gen)
