Results 1 to 4 of 4
- Sep 2007
- 9
November 4th, 2007 06:50 AM #1hi, anyone out there..... engine won't catch, checked fuel delivery lines no supply, suspect engine shut off switch is stuck in off positiion, any other issues i should look into? Thanks guys
- Feb 2008
- 19
- Sep 2006
- 1,335
February 17th, 2008 03:02 PM #3hi, anyone out there..... engine won't catch, checked fuel delivery lines no supply, suspect engine shut off switch is stuck in off positiion, any other issues i should look into? Thanks guys
Check your fuses and loose / corroded harness connectors. And don't apply 12 volts to any part of the injection pump harness. These are the only things you can do.
Normally, this problem is not for DIYs.
Good luck,
Dieseldude
February 18th, 2008 08:51 PM #4
Go to a certified service center. Avoid bringing it to just any mechanic. Ingat sa murang mahal! Mura ang estimate pero dahil nasunog lahat ng electronics lalabas na napaka mahal.
If purely for City driving then get the Emax7. since you already have other cars for longer drives....
BYD Sealion 6 DM-i
