Results 1 to 10 of 57
- Aug 2004
- 108
May 7th, 2007 11:17 AM #1What battery brand do you use for your diesel powered engines? Motolite doesn't recommend the Enduro line for diesels daw because of the high temperature engine bay, they recommend at least the Gold.
May 7th, 2007 09:25 PM #2
try imarflex, but lalagyan mo ng water regularly but significantly cheaper than motolite. if the 3sm fits, get that.
May 7th, 2007 09:27 PM #3
I've always used Motolite Excel in our diesels. And each have lasted past its warranty period.
May 7th, 2007 10:18 PM #4
Motolite Ordinary lang na pang diesel 3sm ang capacity. Medyo mas malakas ang requirements ng diesel engine sa battery sa starting ng engine compare to gas engines. Battery for my Urvan last at least 2.5 years. Alagaan mo lang sa tubig huwag mo hayaan matuyo at huwag mo pupokpokin yung terminal. Kahit bago yan pag napukpok terminal at naputol connection sa loob sira na battery mo.
May 7th, 2007 10:24 PM #5
Motolite Gold 3SM for my 2002 Sedona. Have changed batteries twice since I got this vehicle. The original Korean brand battery died after its warranty period, as did the first Motolite Gold that I replaced it with.
- Feb 2007
- 76
May 7th, 2007 11:02 PM #6nakita ko sa L300fb namin, Motolite Enduro, ung white.. mahirap magkarga lalo na pagna stambay ng matagal.. mga 2 days.. 2-3 tries ang starting..
kailan ba malaman kung tapos na warranty period nya?
- Aug 2004
- 108
May 8th, 2007 04:56 PM #7from date of purchase yung warranty. the enduro has 15 months warranty pero hindi yan sya specified for the L300 so baka ma void yang warranty mo. The enduro is a low-end maintenance free battery designed for normal use gas powered cars. The recommended battery for diesel engines is at least a Gold or the Excel for maintenance free. Pag gusto mo heavy duty meron Motolite Truckmaster my 3SM yata nun.
May 8th, 2007 05:21 PM #8
motolite excel ko nov '01 pa (white) quick starting pa rin. after the
warranty period binuksan ko na sticker to fill it up with distilled water at
nalagyan ko pa ng cement neutralizer noon yung isang butas(more
than a year na) baka yun ang nakatulong.ngayon nga green na ang excel.
May 9th, 2007 05:48 PM #9
Magkakano ba ang battery ng diesel over there? Here in the US I have a Die Hard International which has been on the car since I got it in 2004. Never had any problems with it! It was manufactured 2001 pa pala. Up until now trouble free siya.
Are you guys particular sa mga group ng batteries? Anybody tried Optima?
May 9th, 2007 05:51 PM #10
I just use Motolite most of the time. Basta tama yung size. Good compromise between cost and performance. Minsan yung Enforcer series, minsan yung full calcium line up.
If purely for City driving then get the Emax7. since you already have other cars for longer drives....
BYD Sealion 6 DM-i
