Results 1 to 10 of 11
- Apr 2010
- 13
June 3rd, 2010 04:38 PM #1I have a '06 Hyundai Matrix 1.5 Crdi. It was unfortunately subjected to the wrath of "Ondoy" last Sept.(underwater for 2 days) I was able to get it running from November till the beginning of April , after several (non-casa) repairs. Now the problem is if i go at around 34-38kph or push a bit heavily on the accelarator the engine cuts out. I can start it up again but it will always shut down with the same circumstances. Is this an EGR valve problem? Hope you guys can help.
Thanks
- Sep 2006
- 1,335
June 3rd, 2010 11:26 PM #3Three things that can be causing your engine to shut down:
- Fuel starvation
- Air starvation
- ECU won't trigger the CR pump or injectors to deliver fuel
A faulty EGR, compounded by other problems in the engine's air intake system can cause a shut down.
I suggest doing a scan. This could pinpoint the problem.
- Apr 2010
- 13
June 5th, 2010 06:33 AM #4Hi, thanks for your replies. Yes , I had fuel filter replaced.
My Matrix is now in Hyundai Global City. The service adviser said that they could not communicate with the ECU. I'm just hoping they fix the problem.
June 5th, 2010 08:18 AM #5
- Apr 2010
- 13
June 13th, 2010 07:46 AM #6I just got the quotation for parts needed to replace in my 06 Hyundai Matrix Crdi (from Hyundai Global City), It comes out at
P186,000. I need to replace the Rail Pressure Reg. Valve, Vaccuum Pump assmbly, High Pressure Pump, Swirl Actuator, A/c switch and Cluster Assembly. This is what i need if i want to get the matrix back to normal.
I highly recommend The Hyundai Global City Service Center, they did a great job getting my car running, even if it is not 100% normal yet at least i am able to use it around town ( they recommend not bringing it to long trips out). They solved it by disconnecting the Crdi. I cannot exceed 3000 rpms though.
If you need service call Mon at Hyundai Global
- Sep 2006
- 1,335
June 13th, 2010 10:05 AM #7
June 13th, 2010 10:13 AM #8
sounds to me they did not fully fixed ur car and yet u paid that huge amount? tama ba pagka intindi ko?
June 13th, 2010 10:54 AM #9
Mahal. Dapat binenta mo nalang yung Matrix mo sa flooded price then buy a different car.
- Apr 2010
- 13
One can only hope.
