Results 41 to 50 of 66
October 9th, 2003 01:10 PM #41Originally posted by jackaroo
Roydok,
Most diffs require a GL5 oil, does your rig specify GL4 only for either diff? What GL rating did you use on the transmission?
October 9th, 2003 01:12 PM #42
Sir Ungas,
I recall sir that the Petron SAE 90 gear oil from most of it's stations are API GL-4. Though I know they do sell API GL-5 oils based from their website I'm not sure if it's available in most stations.
Tsikot Member Rank 3
- Dec 2002
- 636
October 9th, 2003 06:11 PM #43Ungas,
If Petron's Sae90 is a GL4 gear oil then ok lang but i'd check to confirm.
Have you tried isolating the noise in the diffs? Raise the front, transfer on neutral, lock the frt hubs and try spinning the wheels thru the front prop shaft. Then try it on the rear diff by turning rear prop shaft(hand brake off). If noise does not appear then it may be transfer or transmission.
Roydok,
Glad that helped and think Sae90 is better for the strada's diffs. What about the tranny, does it need a GL4 or5?
October 9th, 2003 09:26 PM #44Originally posted by jackaroo
Roydok,
Sir the Strada tranny requires SAE 90 and API GL-4. I did not replace it with GL-5 sa casa since it's already GL-4. Thanks again sir.
October 9th, 2003 09:49 PM #45
I never really tried to isolate the sound. I will as soon as I visit chieffy's station.
- Jul 2003
- 58
July 21st, 2004 04:23 PM #47
I also used 140 GL-5 sa rear diff of my Feroza. Kasi I can't find a 90 GL-5. It was either mas malapot (140 GL-5) or less lubricating properties (90 GL-4). I put Shell Spirax Axle oil, GL-5. I had to DIY since Shell does not want to put it themselves
Most gas stations only have GL-4 rating grear only, sabi sa akin dati mayroon daw sila pero konti lang nagpaservice na trucks. Good only for cars and trannys. Once I find a 90 GL-5 I will replace it again.
July 21st, 2004 05:40 PM #48
jkyamog: I changed my rear differential oil a few days ago to Mobil 1 Synthetic Gear oil 75w90. So far so good. P700/quart sa True Value Rockwell.
- Dec 2002
- 636
July 21st, 2004 06:56 PM #49There's Mobilube HD90, GL5 at P95/L if bought by box of 6x4L. You'll have to pool a group of friends to finish 24L!
- 350
July 21st, 2004 08:32 PM #50Magtatanong na rin po regarding gear/trans oil. Ilan liters kaya aabutin para sa pajero? And saan mas ok mag pa change ng trans. and gear oil? Shell, caltex or petron?
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
