Results 1 to 10 of 18
- Apr 2009
- 272
September 22nd, 2017 09:43 PM #1Na observe ko after changing my oil from 20w50 to 10w40 and also from bosch platinum spark plugs to OEM spark plugs, fuel consumption ko naging 5km/liter na lang. bago din naman ang air filter. car is 1997 corolla 1.6 gli with 123k mileage. Ano kaya ang problem?
- Jul 2015
- 9,583
September 22nd, 2017 10:16 PM #2
- Apr 2009
- 272
September 23rd, 2017 02:18 AM #3
September 23rd, 2017 02:43 AM #4
other symptoms?
September 23rd, 2017 06:42 AM #5
Check tire pressure..
Aircon compressor bearing/ pulley bearing
Rear brakes/ Handbrake cable
Check for fuel leaks
Check- aircon aux fan/and condenser...
Check your car aircon for high pressure
And Balik mo lahat ng ginagawa or pinalitan mo dati...like oil.. spark plus etx.
- Aug 2013
- 475
September 23rd, 2017 05:18 PM #7
September 23rd, 2017 07:36 PM #8
maybe its the other way around. baka gumanda hatak ng makina since manipis oil na ginamit kaya naging mas aggressive driving style ni TS at tumaas fc
seriously, TS just get back to the old oil and spark plugs. using thinner viscosity oil may not be that good to a 20 year old engine seals..
September 23rd, 2017 11:03 PM #9
- Jul 2009
- 153
September 24th, 2017 01:41 PM #10Check mo dipstick kung nababawasan ng langis or check mo tambutso kung meron na kaunting usok lali na pag dinidiinan yung gas pedal. Pag positive pareho ang dahilan nyan ay yung paggamit mo ng manipis na langis. Dahil medyo luma na, maluwag na yung mga piston ring at sumusuot na yung langis sa compression chamber. Kasama na sya nasusunog dun at hindi na tuloy maganda and air-fuel mixture kaya mababa na efficiency ng makina.
If purely for City driving then get the Emax7. since you already have other cars for longer drives....
BYD Sealion 6 DM-i
