Results 1 to 2 of 2
- Oct 2010
- 1
September 20th, 2011 12:53 PM #1hello mga gurus,
I just want to consult my problem, last month i've done a major job sa car po, overhauled, new cylinder head, after 7 months na naka tambay and umandar din ulit. we changed my fuel pump (my ride po pala is an old nissan b13 eccs) every morning i idle it for 15-20 mins and minsan drive it around our village. after 2 weeks the return hose ay nabutas(after idling it naka park lang, tumagas gas, thas why i see the hose butas), grabe ang lambot talaga.then replaced the hose after 2 weeks butas ulit, now ayaw na umandar but redondo naman after replacing again the hose with branded ones. suspect ko 1.) may bara sa fuel line, 2) nasira na ulit yung fuel pump (eh bago yun diba) by the way yun po palang gas gauge ko sa dashboad di na gumagalaw (may connection po kaya yun?) cya nga po pala nilagyan ko ng gas yung tank before ko try patakbuhin. any suggestions, Help po. thanks
September 25th, 2011 08:52 PM #2
try cleaning your fuel tank. 7 months na nakatambay, as you said. chances are, kinakalawang sa loob ng tangke, dahilan upang magbara. hope this helps.
2025 BYD Seal 5 Premium Review: Best value hybrid at PHP 1.2M? AutoIndustriya - - - - - - - - -...
BYD Philippines
