Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Please post how many liters of oil are needed for the following engine sizes:
    1. for 1000cc-1500cc engines
    2. for 1600cc-2000cc engines
    3. for 2.2 lt. – 3.0 lt. engines
    4. for 3.2lt. – 4.0 lt. engines
    5. for 280HP - 350HP engines
    6. for 400HP - 500HP engines
    Many thanks in advance!
    Aug 2004
    Weh?
    1.6 liters, usually 3.5 liters of oil
    2.0 liters, around 3.75 liters of oil.
    This varies per model and engine, but that's the general rule.
    I don't know about 2.2 ltr - 4.0 ltr engines. Maybe someone else can help.
    There is no general rule as to the oil capacity of engines depending on horsepower. For example, a 2.0 liter 4G63 Evo engine requires maybe 4 liters of oil, and produces the same power as a 5.7 liter V8, which would require more than 10 liters of oil. It really just depends on the size of the engine.
    Thanks niky for the info. Approximate lang naman ang kailangan ko for the engine size ranges.:nerd:
    Our 4.2L diesel engine need 10-11 liters inbetween oil changes.
    sa 2.2 ko 5 liters
    Aug 2004
    sir peace tayo ha.
    sir, siguro naman po kung bumili tayo ng auto may owners manual po naman po un. dun na lang po natin verify kung ilan talaga ang kailangan na langis ng engine natin para mas safe bago tayo maglagay at bumili kung ilnag liters na gagamitin natin. thks po.
    peace po
    my 3.0 liter ZD30 engine uses 8.1 liters of oil. earlier models of the same engine uses only 6 liters of oil. after they found out it was not enough (crank case cracking), they modified the oil pan to a bigger one to accomodate more oil.
    Signature
    Suzuki Samurai 1.3 l - 3.5 liters
    Pajero Gen1 4D56 2.5 NA - 7 liters
    Nissan Patrol TD42 4.2 l - 11 liters
    Toyota Corolla XL 1.3 - 3 liters
    Toyota Corolla DX 1.4 l - 4 liters
    Jan 2004
    Accdg to the owner's manual, the 4A-FE (1.6L) requires 3.2L of oil. Pero nung sinalin yung 4L container, parang mga 0.5L na nga lang ang natira... Hmmm...
    Aug 2004
    Ganuun usually... whatever the manual says, most 1.6s only take 3.5 liters to get to the F mark on the dipstick.
ENGINE SIZE/DISPLACEMENT vs OIL CAPACITY
