Results 1 to 10 of 21
- Apr 2014
- 231
August 21st, 2015 12:17 PM #1Which engine oil is better ????
Caltex, Shell, Castrol or Mobil ??????
- Jun 2005
- 3,774
August 21st, 2015 12:25 PM #2depends on how you define "better". personally, i just get one that fits my budget and change evry ,5k kms
madami na comparison ng oils dito
you might want to search and backread.
- 54,198
August 21st, 2015 12:32 PM #3- - - - - - - - - - - - - - - - - - - - - -
that depends... are you a'buyin' or are you a'sellin' ? heh heh.
what i do, once my car gets out of casa warranty, is go to the hecho derecho gas station for my oil change needs. i use whatever they have on the cheaper shelf, as long as it is engine spec.
i have been dong this for over 10 years now, and none of my cars, gas and diesel, are showing signs of dislike..
- Apr 2014
- 231
August 21st, 2015 01:44 PM #4
- 54,198
August 21st, 2015 01:48 PM #5- - - - - - - - - - - - - - - - - - - - - -
save for the horrendous cost of the synth, i don't see any advantage..
we have been using mineral only.
we used synth once, in our old workhorse.. tumulo! dahil mas mallit ang molecule size ng synth daw.. balik mineral kami.
if your engine is older, you might expect the same..
let's see what the others have to say.
good luck.
- Jul 2015
- 9,583
August 21st, 2015 02:12 PM #6As long as you change your oil on a regular basis, any of the 4 will do, check the manual for recommended viscosity, every 3k kms is a good interval for mineral oil.
- Jul 2016
- 9
July 19th, 2016 09:56 PM #7I've heard that Bardahl Oil is the best engine oil
Bardahl is often tested in everyday use. The most challenging and hardest on engines is the demanding No-Oil Run. there was a test consists of adding Bardahl to an engine, letting it run for only a few minutes, draining the oil out of the engine completely and then driving a distance of more than 200 miles (350 km).
July 20th, 2016 12:14 AM #8
- Feb 2017
- 8
February 14th, 2017 07:57 PM #9OT lang mga sir, pero kung hindi madalas gamitin ang ride, kelan ka magchange oil?
Kahit gamitin ko ang ride ko to work ng five days a week (about 15 Km roundtrip) e baka 7-8 months pa bago umabot ng 3K ang mileage ko.
Ano ang rule of thumb sa kaso ko?
February 14th, 2017 08:28 PM #10
You can probably get away with 9-12months with fully synthetic oil if its a gasoline engine.
It's about 1 cm longer than the 3SM and about 4 cm longer than the DIN74. And it's also in the 10k...
