Results 11 to 18 of 18
December 5th, 2017 05:53 AM #11
Typically, dashboard warning lights and indicators are not used for diagnosis. They're basically warning and indicators that can go bad and are not accurate. Use either a stick thermometer or an infrared non contact thermometer.
The erratic operation of the dash temperature Gauge might be the cause of the concern
.Last edited by jick.cejoco; December 5th, 2017 at 06:51 AM.
December 5th, 2017 08:39 AM #12
December 5th, 2017 08:45 AM #13
well i was also thinking waterpump was not working so what i did was i poured water on the radiator but did not fill it all up barely above the holes when you're looking inside the radiator and then i revved the engine and saw that water is moving to the right which got me thinking that waterpump is working, though im not so sure if this was the correct method of testing the waterpump... if this is correct i'm setting my eyes on the rad cap...
December 5th, 2017 08:47 AM #14
So, in other words, it is not overheating but hotter than usual. The cooling efficiency is dependent on other factors:
1 ambient temperature
2 engine combustion efficiency
3 airflow across the radiator
4 liquid coolant composition/age/purity
5 condition inside the radiator
6 surface condition of the external surface of the radiator
7 state or condition of the thermostat
December 5th, 2017 09:53 AM #15
title says "heating up *70kph"
1. ambient temperature - maybe i can also use the term hotter than usual, it was kinda hot that day...
2. engine combustion efficiency - i don't know how to answer this
3. airflow accross the radiator - if you're asking how powerful the airflow is, its like #3 on an electric fan...
4. liquid coolant composition/age/purity - i just use tap water
5. condition inside the radiator - i'm not entirely sure but when i look inside the radiator the fins doesn't look clogged and the surrounding area is clean.
6. surface condition of the external surface of the radiator - the external fins (if that's what you call 'em) are not dirty but i'm not saying its totally clean, hehe
7. state or condition of the thermostat - this i cannot answerLast edited by box_type; December 5th, 2017 at 09:59 AM.
December 5th, 2017 09:59 AM #16
I copy, Toyota 4af not 4afe.
Check the ignition timing.
Check the engine vacuum at idle- 17- 21 inHg.
If the air/fuel ratio is a little bit lean or there is manifold vacuum leak, expect higher than normal engine operating temperature.
December 5th, 2017 10:23 AM #17
December 5th, 2017 11:06 AM #18
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
