Results 1 to 6 of 6
- Jan 2014
- 57
February 1st, 2014 12:06 AM #1Mga sir ask ko lang kung worth it ba yung NGK high performance na spark plugs compare sa normal na NGK sparkplug. Based kasi sa mga nabasa ko mas na buburn ng ayos yung fuel so mas tumataas ang mileage ng sasakyan. Sino po may advice based on experience?
February 1st, 2014 12:45 AM #2
What model, specifically?
Fuel economy will not improve with a change of spark plugs alone. Not unless the previous spark plugs were the wrong height and heat range for the engine.
- Jan 2014
- 57
February 1st, 2014 02:54 AM #3plan ko sana palitan spark plugs ng exalta grandeur ko. So it does not make any difference compare to the normal one? Mas matagal lang siguro usage nia?
February 1st, 2014 08:18 AM #4
Sir niky... Yung focus ko... Lumakas sa gas... do I need to change sparkplugs... ?
Sent from my C2305 using Tsikot Forums mobile app
February 4th, 2014 02:04 PM #5
Spark plugs only do one thing.
To spark.
They do not provide the electricity needed for the spark, the ignition system does that. It is always wise to use the sparkplug recommended by the vehicle manufacturer.
February 4th, 2014 02:33 PM #6
If you will use "high-performance" spark plugs, use NGK platinums that are equivalent in design and heat range to the NGK plugs that already come on your car. And yes, mas matagal yung life niya... which is about the only reason to upgrade.
Depends on why. Pulling the plugs will tell you if they're healthy (slightly reddish tint) or if your engine is running rich. (Black) If it's the latter, then you might need to clean your MAF sensor or check your O2 sensors.
If purely for City driving then get the Emax7. since you already have other cars for longer drives....
BYD Sealion 6 DM-i
