Results 1 to 6 of 6
April 30th, 2011 12:37 PM #1
What can happen if I install a spark plug with 1.1 spark gap when my car's manual recommends a 0.8 spark gap? My second hand Vios 1.5G had 1.1 spark plugs installed (last tune up when bought was Shell service station) so when I had it tuned up recently, they also installed 1.1
I've been driving it for a year and it runs smoothly naman, except that it feels a bit underpowered at times. I'm also concerned about long term effects of a wrong sized spark gap, if any.
TIA!
- Apr 2011
- 27
April 30th, 2011 02:52 PM #2
April 30th, 2011 04:56 PM #3
- Apr 2011
- 27
April 30th, 2011 09:10 PM #4
Different spark plug gap size from the manufacturer's specs will cause premature wear of the electrodes, causes misfires, early fouling.
I got the info from the Service Manual (not Owners Manual) of 2007 Yaris with 1NZ-FE engine (same like yours). Also if your plug is NGK BKR5EYA-11, the last numbers corresponds to the gap of the plug.
0.8 mm spark plug is also used by Toyota for the 1NZ-FE. Follow this link for the explanation. http://myviosjournal.blogspot.com/20...ark-plugs.html
May 1st, 2011 11:32 AM #5
Ok, thanks a lot! Read the article, too, thanks! At least I don't have to change spark plugs :P
I feel the same way. Not a fan.
2022 Mazda BT-50 (3rd Gen)
