Results 911 to 920 of 1853
- Jan 2013
- 139
January 26th, 2013 11:45 PM #911sinubukan ko lang kanina ito after magpakarga ng krudo sa urvan. mukhang lessen nga ng onti ang vibration.
- Apr 2009
- 97
February 15th, 2013 12:07 AM #912Nagparehistro ako kanina,
Bago umalis ng bahay naglagay muna ako ng 2T (petron)...
..with correct ratio..
Ang opacity ay 1.0 at no black smoke.
4d56 Turbo 1997 spacegear.
5months old na ang langis ko, with dirty airfilter at nasa 4500Kms. na ang mileage ng langis.. ( i keep track all my change oils, next month ko na lang sila papalitan ng sabaysabay)
Sa emmision center hinataw pa talaga halos 3000rpm ang ginagawa, buset yan di na nahiya
Sinisilip na nga...
Samantalang yung adventure na kasabay ko halos 2000 rpm lang ginagawa...
To all, maraming sa salamat sa mga patotoo ninyo sa experience sa 2T.
- Feb 2013
- 19
February 20th, 2013 04:10 PM #913Good day!
I would like to ask kasi di ba may reserve na 10 liters yung tank by the way may van is delica 1992 halimbawa mag karga ako 800 pesos so mga 18-19 liters meaning atleast 95 ml of 2T di ba i add ko pa ba ung reserve na 10? bali 29l = 145 ml of 2T? tama b computation ko and kahit anong 2t po ba basta hindi synthetic medyo malakas vibration ng van ko and pag umaga pag cold medyo umuusok pero pag uminit na wala namang smoke. Answered prayer to if it will fix some issues. Galing ni TS
February 20th, 2013 05:09 PM #914
i had no problems adding 2t to my 15 year old 1st gen sportage, but a bit of warning to those who wants to risk using 2t in their old diesel veh(esp those used cars from other countries), before adding 2t, be sure to check your fuel tank for rust or gunk, if present, have your fuel tank and the fuel line from tank-to-filter rehabilitated first. adding 2t will loosen all dirt and rust which will accumulate in your filter but some may pass and will do damage to your injection pump... as what happened to my brother's veh which experienced an injection pump seizure due to dirty fuel after 2 months using 2t. they traced the dirt coming from the rusting inside of the fuel tank.
- Feb 2013
- 19
February 20th, 2013 06:17 PM #915
February 20th, 2013 06:39 PM #916
February 21st, 2013 01:02 AM #917
diesel fuel tank rusting is not common on locally bought or regularly used vehicles, it is mostly found on imported used cars that have been sitting at junkyards for many years before being shipped here. what is common here is mixed dirt and water(gunk) you get this from fuel stations with contaminated fuel tanks. the dirt/water mixture usually stays at the bottom of your fuel tank until gunk accumulation plus the loosening-up of rust due to introduction of 2t will start contaminating your fuel line and filter. in my brother;s case it took only 2 weeks for the filter to clog thats when the veh started to chug like a pump boat or something like a vw beetle. he changed the fuel filter and the chugging disappeared but the symptoms returned right after 2 weeks, changed the filter for the 2nd time.... until the injection pump seized, i guess some of the gunk got passed or have been passing for a time now. but dont worry, local shops can check your tank and they know how to clean/rehab fuel tanks.... and use quality fuel filter.
- Feb 2013
- 19
February 21st, 2013 10:52 AM #918
- Aug 2011
- 674
February 21st, 2013 12:09 PM #919First thing to do. Consult your manual if what is the total capacity of your fuel tank. If manual is not available, Mr. Google is available to help you. If it not available in Google, take your vehicle to the nearest gas station for a full tank. If hindi mo pa rin ma-gets, enroll ka uli sa Grade 1 this June.
For 2T+Fuel computation, read page 1.
2T or Diesel first?- It was mentioned for the nth time if you read the thread.
- Feb 2013
- 19
February 21st, 2013 02:04 PM #920Mga sir i would like to clarify about sa computation when pouring 2T pati b ung rserve ng 10 Liters ng tank e kasama sa computation example if pa karga ako 10L diesel + reserve = 100ml 2t tama po ba sir ry? Lastly which is will be first to pour the 2T or diesel. Thankyou so much mga Sir!
It's about 1 cm longer than the 3SM and about 4 cm longer than the DIN74. And it's also in the 10k...
