Page 138 of 186 FirstFirst ... 3888128134135136137138139140141142148 ... LastLast
Results 1,371 to 1,380 of 1853
    Oct 2011
    #1371
    Sir ano ginamit mong brand na diesel fuel treatment? ung cyclo kasi nasa Php360 per 200ml bottle baka meron mas mura....
    #1372
    ^for diesel purge, LiquiMoly Diesel Purge ang sikat sa international forums.
    Aug 2009
    #1373
    I did with my rig c/o joseph a using liqui moly diesel purge.
    Sent from my GT-N7100 using Tsikot Forums mobile app
    #1374
    a little off topic.... for those who are regular users of 2T, do you still use a diesel purging or treatment system to flush out carbon deposits that had build-up? or using 2T will suffice.
    IMO, no need. Carbon once deposited needs mechanical cleaning not unless you're using DPF that burns the soot every regen cycle.
    I use 2T to guarantee lubricity but i'm more concered with cleanliness.
    High pressure commonrail works on tight clearances and were dealing about as little as 2microns and some water to destroy the fuel system. Ph belongs to the supply chain of dirties fuels, the contamination starts from materials handling - transport to storage.. I'd still go for good filtration than additives.
    #1375
    A friend of mine asked me what if you stopped using 2T? what are the effects and would your engine suffer for it? I was thinking that it would just revert back to its original state prior to adding 2T but I am now wondering whether there would be some other effect as well. To the gurus, care to share your expertise on this matter?
    Oct 2011
    #1376
    baka bumalik ulit pagkasira nung fuel float switch? lol. kidding aside. tingin ko, wala naman adverse effect sir added lubrication lang naman un 2T. meron ba dito sa tsikot who stop using 2T na?
    #1377
    I dont regularly use 2T. Minsan nakakalimutan maglagay. Minsan kapag naalala i just pour the 400mL bottle content in the tank kahit half pa ang fuel mark. For me, added insurance lang. We dont really know how the fuel is being made, different brands using different euro standards & additives hence varying lubricity quality.
    Oct 2011
    #1378
    pag nag add ng 2T sa gas station alam na na tsikoter.
    Oct 2011
    #1379
    A little off topic..... 2T is mainly for adding lubrication for diesel fuels. But how about the engine? I saw oil engine treatment products like STP brand. Does it increase your oil TBN? and does it prolongs the life of your engine?
    #1380
    Increases TBN, usually by adding ZDDP w/c is zinc. Antioxidant properties of ZDDP increase the life of engine oil.
Diesel owners that add 2T oil to fuel
