Results 631 to 640 of 1853
- Aug 2011
- 674
May 28th, 2012 02:16 PM #631
June 8th, 2012 04:01 PM #633
Langhiya, kakatapos ko lang basahin 64 pages!
Tanung ko lang, para san ang pag gamit ng 2t sa diesel? JK! Hehe!
Nakita ko tong thread kasi naghahanap ako ng Diesel Injector Cleaner/Additives. Sabi kasi ng mekaniko ko, kailangan ko na palinis injector or calibrate (Isuzu Trooper 4JG2). Naisip ko try muna Injector Cleaner.
Alternative na ba ang 2T sa purpose built injector cleaner? O mas ok ba mag Injector Cleaner muna tapos maintain with 2T.
Quote ko lang din page 19-
June 9th, 2012 11:38 AM #634
2T is a injector cleaner using it every tank will keep your nozzle clean as well as your combustion chambers. It also reduces emissions so less carbon buildup in the combustion chambers and less soot.
- Jul 2008
- 7
June 10th, 2012 10:30 AM #635I have been using castrol 2T oil on my 2002 Ford Ranger 2.9 liter diesel engine for about 1000 km at the recommended ratio of 200:1. Engine sounds and feels smoother than before and my FC increased from 7km/ ltr to 9km/ ltr. This result is amazing considering that my ride was a victim of typhoon Ondoy. Thanks a lot dvdloc.
June 16th, 2012 01:18 PM #636
Good day to all 2t users... I read this thread and im very impresed with the result after adding 2t to diesel... We have a toyota grand hiace 3.0tci. I will try it also and observe what will be the effect to the engine FC.
June 16th, 2012 06:00 PM #637
hi to all 2T users, just completed reading 64 pages of interesting and informative thread...i become a believer with the use of 2T. i definitely will try adding 2T oil in my ford ranger 2004 model and Isuzu ELF truck...
how about Montero GTV 4d56 turbocharged engine, have anyone tried adding 2T in the fuel? i only used v-power and petron TD in my 3 mos old unit...
June 16th, 2012 08:04 PM #638
- Apr 2012
- 113
June 16th, 2012 08:59 PM #639
- Jul 2008
- 935
June 16th, 2012 09:11 PM #640Naglalagay na rin ako ng 2T sa GSR ko, bale approx 30mL for a P500 gas...
I got better responce and lesser noise from the engine and lesser vibrations as well.
How much room do you have between the battery terminals and the hood seeing the the 3SM is much...
