Page 1 of 4 1234 LastLast
Results 1 to 10 of 1853
    Dec 2007
    Tried this just last week during refilling for full tank. Used up 200ml for 90ml for 90 liters. Have not researched correct ratio yet that is why. But knowing that it burns with gasoline and it has decarbonizer (Shell 2T), I assume that it will help clean the exhaust parts. have not really checked whether it improved the engine noise. Will check next time when I refill again.
    based on my research, ratio is .8ml for every 1 liter.
    You are correct on the ratio. .8ml per liter is 200:1 or about 1 oz per gallon. Even when I was trying it with only 17L of fuel and my brother in law put in 8oz I had no issues. for a fuel tank which is 76L for me I just dump a full 8oz bottle in. It does not have to be 200:1 the minimum should be 128:1 ratio. I only added more than 8oz a few times since I normally run bio-diesel from flying V.
    Yup I also add 2T on my diesel fuel. I'm using the 1:200 ratio.
    Correct me if my interpretation is not right coz i use 200ml 2T for 40 liters of diesel fuel.
    so, 1 liter 2T: 200 liter diesel or 0.5 liter 2T : 100 liter diesel
    or 0.25liter 2T : 50 liter diesel, thus 0.2 liter 2T : 40 liter diesel
    or 200mL 2T : 40 liter diesel.
    if you use 0.8ml 2T: 1 liter diesel or 0.0008 liter 2T : 1 liter diesel or
    0.08 liter 2T : 100 liter diesel or 0.16 liter 2T : 200 liter diesel
    thus 1 liter 2T : 1250 liter diesel.
    [SIZE="4"]elow guyz...
    Can I also add 2T oil to my 1999Hi-ace with a 1KZ-TE engine? Will it damage the turbo?
    TIA...
    [/SIZE]
    Quote Originally Posted by erick_214 View Post
    [SIZE=4]elow guyz...
    TIA...
    [/SIZE]
    sir bawal po text speak
    Dec 2007
    TIA...
    [/SIZE]
    Works well with any old school mechanical diesels, these are the ones that were not designed to be used with the new low sulfur diesel fuel that has been forced upon everyone. So give it a try and let us know if you can hear and feel the difference.
    Dvldoc, so using anything lower than FD is fine? Best if FC?
    [SIZE="4"]
    Gusto ko talaga subukan kaso nga lang talagang kinakabahan ako baka masira fuel pump at magbara yung fuel filter...Pero sige I'll give it a try...So BIG QUESTION, kung magpapakarga ako ng 50L na diesel gano karaming 2T oil ang kailangan ko?
    TIA...
    [/SIZE]
    Dec 2007
    [SIZE=4]Gusto ko talaga subukan kaso nga lang talagang kinakabahan ako baka masira fuel pump at magbara yung fuel filter...Pero sige I'll give it a try...So BIG QUESTION, kung magpapakarga ako ng 50L na diesel gano karaming 2T oil ang kailangan ko?[/SIZE]
    [SIZE=4]TIA...[/SIZE]
    Around 13oz of 2T
    *Crazyboy
    Yes you can use lower like FB or FA. FC is low ash so it burns much cleaner. Lubricaton is basically the same. For me anything to protech my injection pump in a grey market vehicle is worth it. I want max life out of my vehicle.
    Around 13oz of 2T
    *Crazyboy
    [SIZE="4"]
    Many thanks..! Try ko ito tom...Kaso nga lang may katanungan pa ako...yung motor kasi ng tito ko na 2-stroke eh nagkakaroon ng matigas na carbong deposit sa pipe niya so every year eh tinataktak niya pipe niya...possible din kaya magkaron niyan sa pipe ng diesel ride natin?
    [/SIZE]
    Apr 2011
    pwedy ba yan sa trooper ng 4jx1?
Diesel owners that add 2T oil to fuel
