Results 11 to 20 of 25
May 5th, 2011 07:54 PM #11
Good oil will do the job to keep the soot particles suspended in the oil, But it's the filters job to remove those particles. suspended soot particles cause tons of wear in your engine. Just because you have a diesel does not mean your oil needs to be pitch black. If you have a filter that can clean down to 10 microns then it will be fairly dark brown. If your running something like a VIC or OEM Toyota you can for get it because they can only get the job done effectively down to around 25 microns. VIC's don't touch particles in the 20 to 5 micron range.
If your past a your warranty might as well run a filter designed for heavy duty fleet use, IE. it gets the job done to keep your engine oil clean. Not to mention they hold up to 3 times more particles before becoming clogged. Cheap filters die early and just go into bypass mode so they just re-circulate dirty oil.
May 5th, 2011 08:16 PM #12
*dvldoc
Maybe we've just all been used to seeing black oil in our rigs before 5tkms on the oem filters lol.Gonna give Fleetguard a crack next oil change.
May 5th, 2011 08:37 PM #13
if medyo OC ka and money to spare... bili ka ng 1-2 sets of oil (yung cheapest you can find) use it for flushing purposes...
drain used oil
then replace with cheap oil
run the engine
drain the oil again
case to case basis if you need a another set for flushing... pero kung religous naman ang change oil nyo sir, kahit 1set lang
then replace with your preferred oil
tried this once, and dami natangal na deposits... matagal bago dumumi ulit langis.. parang brand new yung appearance ng oil sa dipstick
May 5th, 2011 10:42 PM #14
May 5th, 2011 11:11 PM #15
May 6th, 2011 12:14 AM #16
My next trip to the Philippines I will be moving there.
Go here they have them, They are a official dealer.
PACER EQUIPMENT RESOURCES INC
NO 214 RIZAL AVENUE EXTENSION BETWEEN 4TH & 5TH AVENUE
CALOOCAN CITY
Philippines
1400
Phone:632 3617 038
Fax:632 3617 043
I am using my LF3487 for a remote mount transmission filter, factory metal mesh filters only filter to like 100 microns, which is not very good. I plan on having my Elgrand last a long long time.
- Nov 2009
- 3,507
May 6th, 2011 12:43 AM #17The dealer have a very old stock(2007) and are rusted with weak springs. I got curious when i heared metal sound while shakin the filter so iopened the can and here it is..
I guess the springs are somekinda loose, but in general that wouldnt matter since oil presure will seal the rubber in the inlet.. I just noticed bypass valve is made of composite fiberboard (like those in printed circuit board), it has some gap though too small to notice..And its microglass is shiny, tried blowing air on it and i could feel its more free flowing. * Dvldoc, is this the same bypassvalve as the new stocks??
- Nov 2009
- 3,507
May 6th, 2011 12:51 AM #18BTT.. As long as your engine is Diesel with EGR valve, your oil would turn dark in just hours of idling.. Remember EGR valve activates only when you are idling.. It totally close/ disabled at high RPM (to seal the turbo boost).. My simple solution for that is to maintain air filter clean, PCV oil catch can, blocking of EGR (in progress), and water injection..
Remember any Emission control device attached to your engine is posionous to your engine:
EGR - Dirty exhaust back to the intake
PCV - Dirty blowby gasses back to the intake
Cat - rob power due to exhaust resistance
[SIZE=2][SIZE=2]DPF - afterburn is not perfect technology and causes many problems due to many sensers..
What else.. urea injection??
[/SIZE][/SIZE]
May 6th, 2011 02:03 AM #19
That sucks that there stock is not well taken car of, having a 6 or 7 year old filter is not a big deal. And they should not be rusted especially if they are stored indoors. I think I am going to eliminate them from my recommendation for filters there since I have already spotted at least 2 Fake filters. Might email fleetguard about them as well to see if there dealer status is still valid.
*12vdc yes the design is the same, most filters do not change unitl after 10 plus years. Then they will have a obsolete part number or updated part number which can be looked up on Fleetguards site.
Never seen a real Fleetguard rust on the shelf, even in high humidity. Looks like they have a mix of fake, plus old and newer stock. Average customer is not going to know what is what.
May 6th, 2011 02:15 AM #20
* 12vdc I can't view imageshack on my work computer so I will check your picture later.
Well just called Fleetguard they are still listed as a dealer as well as the one in Laguna, but we all know how things go there, some people will cut coners to make money.
. CUMMINS SALES & SERVICE PHILS. INC.
LOTS 1 & 2 BLK 15 LIIP AVE. LAGUNA INTERNATIONAL IND PARK MAMPLASAN,
BINAN LAGUNA
Philippines
4024
Phone:632 8430 630
Fax:632 8430 703
I got all my stock in the states and they all look prestine and I have just over 600 filters.
Buyer beware I guess.Last edited by dvldoc; May 6th, 2011 at 02:49 AM.
If they offer it with 16 or 17" I'd buy it.
Honda BR-V
