Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Mga tsikoteers, ask ko lang kung ano kaya nangyayari sa makina ko kasi nabubulunan sya paminsan-minsan tuwing bumibiyahe ako. Yung tipong na cho-choke sya tapos babalik ulit sa dati, minsan nung nasa fourth gear na ako biglang na choke parang nag preno tuloy ako bigla. Kakatakot din ang ganun lalo kung mabilis biglang bababa RPM mo. Ano kaya to? Toyota Corolla po gamit ko.
    Apr 2008
    ipa check mo rin yung brake pads mo sa harap baka bakal sa bakal na, nangyari sakin yun dati kala ko sa makina pero nung patingnan ko yung brake pads sa unahan upod na daw dumidikit na.
    Nov 2003
    if it's a carb engine it might be time to overhaul the carb. if it's injected look at the fuel system and ignition.
    bagong palit lang ng brake pad ko at na overhaul/cleaning narin pati sa likod. siguro sa carb na to. may kinalaman ba to kung nag baba ako ng octane level? 95 gamit ko pero nagbaba ako sa 93.
    Jan 2008
    check your fuel pump / fuel filter..
    Apr 2004
    pa linis mo ng compressed air yung air filter mo dude
    That's what i'm thinking mga tsikoteers, ipapa-check ko yung fuel filter ko pati air filter ko. Kasi parating malapit na ma fuel empty ako kaya na suck nya yung latak ng gas ko. pati na rin yung air filter ko na madumi na rin.Ayun kaya yung problema nun? kasi nabubulunan sya na parang biglang nag low gear, kakatakot lalo na pag nasa highway, biglang nabubulunan.
    Jan 2008
    well from my experience.. I have drained and pulled down gas tanks from two vehicles, one is from a 1995 Nissan Vanette (gasoline) after 8years of usage and from our Assembled AUV (diesel) after 10years of usage, and to my surprise i didn't find any "latak" formation, sediments or anything of different in nature aside from the fuel!! its clean!! very clean inside... but what i have noticed is dirty FUEL filters that when agitated will release black, dirty fuel inside which indicates it needs replacement...
    I suggest you change fuel filters and check your fuel pumps for functionality..
    Thanks Yapoy, I'll do that.
    Jul 2006
    Parehas tayo problem sir corolla gli, nag chochoke siya, kapapalit ko lang po ng timing belt and chang oil pati sparl plug now plang siya nag 80k since 95, bihira kasi gamitin, pero nag chochoke sya hindi ko alam bakit, help po naman mga gurus
Choking!
