Page 8 of 8 FirstFirst ... 45678
Results 71 to 77 of 77
    Apr 2008
    #71
    EFI syempre! There are a huge boatload of reasons why they don't make them anymore.
    May 2010
    #72
    EFi syempre.
    Carburetors are very inconsistent.
    May 2010
    #73
    Maiba lng carburetor
    Why????
    Please don't ask me.
    #74
    Quote Originally Posted by SiRbossR View Post
    EFi syempre.
    Yup. To maintain the optimal FC on our aged Sentra B13 with a carb, i have to clean the air filter and adjust the a/f and idling every so often (maybe once every three months). My EFI Altis will always keep a constant FC even if its due for servicing. Drive up to high places where atmospheric pressure changes, you have to readjust the carb. With EFI, nothing doing.
    Jan 2012
    #75
    carburetor engine vs efi engine
    - advantage and disadvantage po mga sir...
    ex. sa pizza carb vs pizza efi
    - maintenance
    - gas consumption
    base on your experience lang po mga sir tnx..
    #76
    Pros:
    Carbs are much easier to adjust, and especially to get more power out of. Cheap to fix, rebuild and easy to trouble shoot.
    Fuel Inj. is more precise, less pollution as the computer is constantly changing air fuel ratio to optimum. More fuel efficient as well.
    Cons:
    Carbs aren't very efficient, they can't make changes on the fly like fuel inj. can.
    Fuel Inj. needs a much higher fuel pressure, which makes line routing and integrity very important. The injectors themselves have small orifices, which can be easily clogged by crud passing filter or scale build up. Fuel injection is expensive, and so is testing or replacing components.
    ... and fuel injection will not keep your car running if you flip it, as your gas tank siphon is mounted on the bottom of the tank,.
    #77
    Quote Originally Posted by ruhtra View Post
    - maintenance
    - gas consumption
    MODERATORS NOTE:
    multiple threads merged
CARB TYPE ENGINE VS FUEL INJECTED ENGINE [merged threads]
