Results 1 to 10 of 13
SiRaNeko
- Jan 2003
- 973
December 11th, 2004 10:40 AM #1example a carb engine na 1.3 lliter,
one is 12 valve and the other is 16 valve
whats the advantage?
better mileage? more hp? more torque?
thnx in advance
December 11th, 2004 11:33 AM #2
carb na 1.3? comparing ka ng corolla xl and mazda 323 ano?
well, answer is all of the above. generally speaking less pumping work and better engine breathing mean more power, torque and better mileage.
December 11th, 2004 11:49 AM #3
Bakit yung ibang highperformance Mercedes SL models ay 3 valves per cylinder lang?
December 11th, 2004 11:53 AM #4
depende rin kung anong made... for example benz is 3 valves lang per cylinder pero masmalakas siya... depende... bigay ka ng specific example...
December 11th, 2004 12:20 PM #5
I think the Merc SL55AMG is a 3valve per cylinder machine... just wondering why Merc doesnt use 4 valves ?
December 11th, 2004 12:33 PM #6
i dont know... pagka-alam ko handmade kasi at designed yun makina ng 3valves per cylinder ata...
December 11th, 2004 01:15 PM #7
ok. put it this way, less is more. more is less. less valve means more mileage. also, less horsepower since less fuel is contained in the chamber. consequently more is less. more valves means less mileage, but more horsepower. self-explanatory, since more fuel is burned thus more energy is produced.
as in the case of mercedes, 3V / cyl? well, check out its displacement and internal attributes such as supercharger or turbocharger, it is well compensated.
hope my point is taken. :D
December 11th, 2004 10:05 PM #9Originally posted by buknoy2002
thnx in advance
December 12th, 2004 09:34 PM #10
Siguro yung single exhaust valve ng 3valve engines is also a little larger in size than the intake valves.. it might improve the reliability of the engine since fewer yung moving parts :-)
One can only hope.
